Hey Guys,
First of all, credits for this forum/website. Lots of good DIY tutorials which convinced me to register here (as well).
I've also asked my question on Volvoforums.org.uk, but since there's a lot of people with knowhow of the AW55-50's here, perhaps you can shed some more light on my problem!
I'm driving a 2004 V70 D5, FWD with the AW55-50SN gearbox since about a year. Ever since I bought it, there was a slight stuttering when accelerating slowly and decelerating towards a roundabout for example. Coming from an old 244 with BW55 transmission I was used to that and didn't think too much of it.
The issue became more noticable though and I decided to do a flush. We used the correct oil (3309 from Mobil) and the old oil was quite bad (dark black...).
For a shortwhile it seemed better, until recently it started to stutter again and in notime I was back to square one. Last friday (when I got married even...) a warning light came on: Transmission Service Required and it went into some emergency loop (wouldn't shift properly from standing still), didn't indicate what gear in etc. etc.
I was able to read the fault codes today (had to install a laptop), and I'm getting a TCM-012C and an additional ECM5310 communication with TCM error (probably consequence of the TCM Error).
Basically the error described that there could be a problem with Solenoid SLS, which pretty much matches the stories I've been reading so far. However considering the description "Neutral Control Engine Flare", I am wondering if I am having one of those old transmissions that needs new software ?
Otherwise - should replacing the valvebody with a remanufactured one resolve my problem?
Cheers,
2004 V70, TCM-012C Error
- Has thanked: 1611 times
- Been thanked: 4075 times
I believe the problem year was 2001 with this transmission, and by 2004 things were better.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
After what I've recently experienced with throttle control errors and the ECM, I would be inclined to pull the TCM loose and re-seat it just in case the problem is simply a bad connection. A special tool is required to release either the ECM or the TCM but a well-versed Volvo mechanic will have that tool. It's a five minute job and requires no new parts. This may not be the problem but it's worth a try.
ohm out the solenoids.
sonnax has a good document about the solenoids testing
http://intertransparts.com/assets/niss_ ... zip-in.pdf
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
Yes, starting by resistance checking the solenoids. Can be done from the Trans to body connectors just forward of the airbox.
Alright, I'll see what I can figure out!
Note though that there was an issue present with the gearbox, but that the warning light itself is a new thing. Is the TCM detachable with normal garage tools? None of my friends have the special 'Volvo' tools, but are skilled mechanics though.
Also, about measuring the resistance on the solenoids. I'm assuming this can be done without the car running right? I found the connectors in front of the air filter, between the filter and the headlights on a small frame. Initially I removed the entire filter as mentioned in VIDA, but no connectors were on the box itself.
- 1159 Views
Last post by packetfire
- 3220 Views
Last post by 2001downunderxc70
- 40 Replies
- 22371 Views
Last post by GDiode
- 10 Replies
- 5524 Views
- 13 Replies
- 6303 Views
