P2 factory amp install kit(PA-200) for Fit: 2001-2009 VOLVO S60, 1999-2006 VOLVO S80, 2001-2007 VOLVO V70/XC70
db130
Year and Model: 2002 V70 T5
Post by db130 »
This kit allows you to bypass the internal amp of a HU-4xx or HU-6xx factory deck and install the PA-200 amp underneath the passenger front seat. This amp was previously mated to a HU-803 head unit. It is rated for 50x4 watts.
I have pulled this amplifier from my personal vehicle (2002 V70 T5) after I upgraded to a PA-300 amplifier. The amplifier worked 100% prior to the upgrade, I guarantee it will be operational upon arrival. Correspondingly, it has a 2002 manufacture date.
Also included is the Volvo factory installation instructions for S60/V70/S80 applications.
The 2 mounting bolts for the amp itself are also included, as is a new 30-amp fuse that are needed to complete the aux amp circuit.
Most P2 cars will likely be pre-wired from the factory to supply ground and power to the amplifier, needing only the included harness to connect the amp to the back of the head unit. This is very much in the realm of DIY and can be installed in ~2 hours or less.
Installation caveats:
1) On some cars, the mounting holes on the floorpan are physically there but they may not be threaded. If that is the case, you will need a M6x1.00 metric tap.
2) The 2 mounting brackets attached to the amplifier will be removed to make shipping easier. You'll need a T10 screwdriver to reattach them.
$100 shipped to the lower 48 with USPS delivery confirmation, Paypal friendly.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
JDS60R
Been thanked: 3 times
Post by JDS60R »
I thought you sold this back in 2015? Is it available?
https://www.matthewsvolvosite.com/forums ... 02#p355202
Retired
db130
Post by db130 »
Hi, the "2015 kit" was a different amp and yes, that one was sold back in 2015.
The amp listed in this ad is available, as is the rest of the kit.
2002 V70 T5 169k
2002 V70 NA 249k
melbaz
Year and Model: 2007 S60 T AWD
Post by melbaz »
Hi , Im thinking I need to replace my amp , how can I tell if I have a p2 or p3 ?
db130
Post by db130 »
Hello, melbaz.
P2 refers to the 2001-2009 VOLVO S60, 1999-2006 VOLVO S80, 2001-2007 VOLVO V70/XC70 models.
Since your signature indicates that you have a P2 S60.... you have a P2.
2002 V70 T5 169k
2002 V70 NA 249k
melbaz
Post by melbaz »
I have the 6x46 , would yours work on mine ?
db130
Post by db130 »
i don't think i know what a 6x46 is, sorry.
2002 V70 T5 169k
2002 V70 NA 249k
melbaz
Post by melbaz »
Hey can I buy the Amp ?
Leroy510
Year and Model: 2005 s80
Post by Leroy510 »
I'm looking for amp and harness. Going from hu 650 th the hu 850 so looking for the amp 200 watt and the wire harness from amp to head unit. Its for a 2005 s80.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Leroy, start a new Topic in Classifieds. Few/none with one will see this here.
Also -> Amazon link
