hello, I have an 07 xc90 with 2 wd and a 3.2 engine. I need some help, today I had to remove the intake cause the altinator went bad, in the process I pulled off the wires to the throttle body. two of them are still connected but the other 4 are just hanging there, hope someone can tell me what order the wires go into the connector thanks alot, I checked the wiring but it is a bit technical for me and I think it calls the throttle body is called something else....\\\
thanks in advance jake
3.2 xc90 wiring at throttle body
jake 32137
- Year and Model: 07 xc90 3.2
jake 32137
if someone could just send me a picture of their s it would be a big help thanks again
jake 32137
wow, guess everyone too busy well, did some looking and found that they call the throttle body the accelerator monitor and I found a wiring manual online so I could re-connect the wires in the right order....
here is a link for anyone who might need it....http://www.volvowiringdiagrams.com/volv ... iagram.pdf
- 3233 Views
Last post by vmaxmike
- 791 Views
Last post by oragex
- 2196 Views
Last post by Goldchemist
- 580 Views
- 716 Views
Last post by Faust
