Rear caliper bleeder screw
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Order yours before removing the old ones and replace asap as the old one is out 8)
For reference, because the web seems a bit confused in numbers, this what the original Volvo part looks like
http://www.skandix.de/en/spare-parts/br ... r/1024017/
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Your old one looks good. Mine on 02 V70 rusted to dust, had to blow torch the stump and extract it.
oragex
Post by oragex »
Well, I thought Montreal had more salt that Boston 8)
It doesn't look too awful indeed, however it's the lone survivor. The one on the other wheel, I succeeded to open it, put it back in place gently tight, one year later it snapped. New caliper on :(
vtl
Post by vtl »
He have a saltier salt here in US :-P
I guess, it depends a lot on how often the car is washed through the winter. Mine was fully neglected until I got it.
Been thanked: 504 times
Post by cn90 »
I think FCPEuro dot com has the correct bleed screw.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I ran into this issue recently also, it can really take the wind out of your sails!
The car I was simply replacing brake fluid on had the VR/SR Brembo calipers too, which have 2 bleeders per caliper. The fun part is the caliper itself is some sort of cast aluminum. On both rear calipers, 1 of the 2 bleeder screws were boogered before I laid a wrench on them. Naturally, the threads in those same bleeder holes on both calipers were gone too. Yeehaw. Not much meat left to chase on the bleeders screws nor in the calipers. I couldn’t even make out what die/tap was appropriate & info online was of little help.
A replacement caliper (reman, painted black) is $250. New, $350-400 PER caliper. I rolled the dice with a clean looking $150 eBay caliper, meanwhile hoping I could salvage one of my two Brembo rears with bad threads. While waiting for the eBay caliper I tried a number of Eskimo tricks & finally succeeded on both calipers.
Over the course of 4 days (and waaay too much brake fluid & cat litter) I finally got them both to take. On one caliper I ended up tapping the casting to 1/8-27 NPT, then installed one of these brake bleeder repair kits. It leaked at first, much to my dismay. Wrapped the brass bushing with Teflon tape (~6 rounds!) & it worked! We shall see how long the Teflon tape survives.
The other rear Brembo caliper I tapped to M10x1.0 and chased the threads on the bleeder to the same, polished the conical end of the bleeder & it’s mate in the bottom of the bleeder hole, wrapped with Teflon tape (for threading traction, not to seal via threads), and in she went. Proceeded to bleed rears (for the umpteenth time) then fronts again, then rears again and finally had pedal feel back.
The ironic part is dealers don’t stock bleeders. I ordered 4 just in case. So yeah, get bleeders ahead of time like Oragex encouraged!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
oragex
Post by oragex »
Can also get them from the junkyard, ones that come out easy should be a good bet.
