power steering leak,1994 850 wagon
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Well today I pulled up on two flat bricks, I was able to clean all the grease off the line underneath,I didn't find anything,I pushed up on the line then looking under the hood where the hose meets the line is the leak,now where the hose goes into the line,there is probably an O ring,am I right??
loveMy850
Im not so sure how to post a pic,My post should have read,how do I change the hose,first time,Im not sure if its the pressure hose ,and do I have to ,well have you ever done this can you help me,Ill give you as much info as I can,just ask,ok.Thanks
loveMy850
Wow I can try,Heck Im hoping Im replying to you correctly, I havent been on the forum in a while,these computers are like shooting pool,you dont use it you lose it, can you post the pics?
loveMy850
very pretty car,mines a tad older,looks like your on the road,I hope to get some good replys on how to fix this power steering leak..Have a safe journey...........
The high pressure line between the pump and rack is solid and doesn't use orings mid-line on my later model. I think your car is the same. You will need a new line or one from a pick and pull ( much cheaper)
- 30 Replies
- 27039 Views
- 619 Views
- 6085 Views
Last post by EngineeringBloke
- 1105 Views
- 3278 Views
Last post by chittychittybangbang
