Beginning my 60 mile drive home with my daughter and a tow truck driver.
At a red light, my 2005 S60 started making a grinding-type sound. Then a few seconds later it died, and wouldn't start again. A couple gentleman helped me push the car across the intersection to park, then I noticed the river of coolant flowing from my car down the gutter.
This car has been well-maintained, with a recent oil changed and a mechanic once-over while getting my front brakes replaced.
Any advice about what might be wrong?
Grinding, coolant everywhere, won't start
Ugh. If the grinding happened with coolant loss on the right side of the car, well underneath, it's probably a seized water pump
The bad news is this ruins the top,end of your engine if it seizes and breaks the timing belt, which happens 95% of the time
In a good shop, it's a 2-3k repair to fix.
abscate wrote:Ugh. If the grinding happened with coolant loss on the right side of the car, well underneath, it's probably a seized water pump
So, if I'm in the lucky 5%, I just have to replace the water pump?
I need to be in the 5% or this is absolute Game Over for me.
If I can somehow get by with just the pump, what is the degree of difficulty for this?
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Been thanked: 3 times
The rule of thumb (on all makes/models) when the timing belt is replaced and the water pump is run by the timing belt.... replace the water pump at the same time the timing belt/idler/tensioner is done. I learned this the hard way (on several different make/models) vicariously, although the WP didn't seize but went the noisy floppy shaft bearing route and they had to go back in and double the job. Never put 1 & 1 together until it was mentioned here in the forum to do it while you're in there. Thinking that your WP didn't get changed. Because I'm curious... how many miles on the car and about how many since timing belt was replaced in 10/2014?
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
I just purchased the car a few months ago (from a trusted friend, with full records and a meet & greet with the car's long time mechanic) so I am not certain how many miles were put on it, though it was used to drive to work and back, so I'd say just an average amount. It currently has 144,xxx on it.MarcM wrote:The rule of thumb (on all makes/models) when the timing belt is replaced and the water pump is run by the timing belt.... replace the water pump at the same time the timing belt/idler/tensioner is done. I learned this the hard way (on several different make/models) vicariously, although the WP didn't seize but went the noisy floppy shaft bearing route and they had to go back in and double the job. Never put 1 & 1 together until it was mentioned here in the forum to do it while you're in there. Thinking that your WP didn't get changed. Because I'm curious... how many miles on the car and about how many since timing belt was replaced in 10/2014?
It seems like changing just the WP is going to be a difficult task, which is really too bad since I am the one who has to do it!
The belt should have been replaced at 105k miles. If it's original then that's probably the failure. Ypu can check this your self by removing the plastic cover on top of the engine ( you will need some torx bit screw drivers) and looking for the belt across the cam pulleys
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I'm interested to know what exactly happened too. Catastrophic failure of the WP is very rare- typically it starts weeping and leaking before it takes a dump!
I didn't realize it was that easy to check!abscate wrote:The belt should have been replaced at 105k miles. If it's original then that's probably the failure. Ypu can check this your self by removing the plastic cover on top of the engine ( you will need some torx bit screw drivers) and looking for the belt across the cam pulleys
No weeping or leaking - straight to dump!MadeInJapan wrote:I'm interested to know what exactly happened too. Catastrophic failure of the WP is very rare- typically it starts weeping and leaking before it takes a dump!
- 21 Replies
- 4889 Views
Last post by befarrer
- 78 Replies
- 12186 Views
Last post by PeteB
- 926 Views
Last post by beigg
- 2492 Views
Last post by midimykeys
- 1795 Views
Last post by difflock54
