Hi guys,
Need some thoughts on an issue that is happening in my 94 850.
Due to a leak I recently replaced the radiator and now the temperature holds steady at 3 o'clock. But, if the car idles for 10-15 minutes, the temperature will begin to climb and will eventually overheat. I've also replaced the thermostat so I'm wondering what the cause of this could be.
Any advice or thoughts would be appreciated.
'94 850 Overheating
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
When the temp rises does the radiator fan kick in? Could be that you missed a connection when you replaced the radiator or the relay is faulty.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
CarVolvo
- Year and Model:
Im with Bill, try turning on your a/c and see if the fan kicks in too.
The only other suggestion is double check on the proper installation of the thermostat. I had a similar problem and it was the thermostat..but the it wasnt a new one..just the existing old one.
Best way to see if the thermostat is working is to put your hand on the hose squeeze it (keep clear of any moving parts) and sense if there is flow to the radiator.
Happy Repairs Forever
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
