recommended mileage replacement of timing belt components
camjohns
Year and Model: N/A 850 97, 850R 96
Has thanked: 6 times
Post by camjohns »
Found this article which showed recommended mileage replacement of timing belt components.
https://www.matthewsvolvosite.com/forums ... hp?t=55365
is this true for my 1997 volvo 850 n/a?
thanks!!
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
Same engine. The belts need to be replaced at 70K miles. Rollers, probably, for sure at 140K. Hydraulic tensioner 180-200K. Water pump at 180-200K.
Of course, if you don't drive much, 10 years is the max for a belt.
Klaus
johno504
Year and Model: 1998 c70 cpe
Post by johno504 »
180 - 200k on a water pump ????? that's a FOOLS game ...........
Has thanked: 311 times
Been thanked: 817 times
The OEM Volvo water pump easily goes 200k.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
johno504 wrote:180 - 200k on a water pump ????? that's a FOOLS game ...........
I would suggest to take a little time for reading and learning about things before claiming something wrong.
Mine water pump was replaced last year at 300+ k km because it started to leak from a weep hole.It was original oem pump.
I'm noticing that there are more and more members who write whatever they want to according to their own understanding and persuasion and without a facts and experience about something.
The worst thing about it is that they are ready to argue about it even if they are wrong which is unacceptable on this kind of forum.
This is not a fight ring,although sometimes i would be more happier that it is since i'm a sportsman,fighter and i train since i was a kid. ;)
This forum was always a best forum with a lots of members who knows these cars like their pockets and i would be happy that it remains like that.
This forum is full of knowledge,experience....etc...and all you need is to ask,read & learn.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
camjohns
Post by camjohns »
Thanks for the info! and yes i thought water pump lasted quite a bit as well. Just replaced mine at close to 300,000.
thanks!
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Everybody's experience will be different but for what it's worth, I waited until 185k miles to replace the original water pump on my '97 855 GLT. It was working fine at the time, with no leaks visible. The inside looked fine when I removed it.
The inside of the original water pump at 185K miles
Volvo water pump at 185k miles.jpg (124.18 KiB) Viewed 4250 times
jreed wrote:Everybody's experience will be different ...
Ah yes!
Key to remember because in the end you have to do the repair in front of you not the one you read about on the internet. And key to forget because whatever happens with your car is but one example and in the forums you can piece together the collected wisdom of dealing with sometimes thousands of examples.
The second point is overlooked so often, I agree with misha it is good to keep in mind how much useful history is packed away in the archives. That search button is, still, your friend! Or the write-ups and videos, there are good ones that summarize what has emerged from the forum discussions. At the same time, parts manufacturers change, the cars keep getting older so different things start to fail, etc., so many repair recommendations are a moving target. At least that keeps it interesting.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Mine was a bit scarier at about the same mileage. I think this one came out of my '94 at, after correcting the odometer, had somewhere around 170 k on it.
That one had no leaks whatsoever.
I am a bit sensitive on the water pumps since I had one fail and take the timing belt with it on my wife's car. Fortunately that engine was a full clearance engine and it didn't take out the valve train. On a Volvo it is a disaster if the pump locks up. My experience with timing belts is that they rarely fail on their own, even beyond the prescribed change interval. It is usually something else that causes the belt to fail like a bad roller, water pump, or a bad tensioner.
Has thanked: 2202 times
Been thanked: 1852 times
Our old V70 XC (98) decided that the time for the water pump to fail was immediately after installing the new timing belt. That was at about 150k, miles. The reality is it is all dependant on what your comfort level is, and experience. I know Volvo used to say every second cam-belt to change the pump. The problem with that is different driving styles and locations (city v's country) can be harder on a pump and engine.
My view is for the price and effort involved I'd rather swap the pump out.
