Emissions test... P0442 p0445
ThommyKent
Year and Model: 91 245 97 850 T5
Been thanked: 5 times
Post by ThommyKent »
On a S80 anyway
Auburn T5
Year and Model: 1999 S70 T5
Post by Auburn T5 »
ThommyKent wrote:
mdvolvo wrote:I worked on volvo for over 25 years but now do it as a hobby.
Here is the fix.
There is a hose that is attached to the evap canister and valve that is cracked. They all do. It is about 9 inches long with a hooked end.
The canister is located above the rear sub frame of the car directly in the middle.
Remove the right rear wheel and look straight through the gap and the one end of the hose can be seen attached to the canister.
Replace the hose and that will solve that evap leak problem
Not too much of a difficult job
I just repaired this hose as it had a very small crack at the hooked end. It fixed the p0455 code that kept returning. Maybe on a lift it`s not to bad a job, but`s not a lot of fun on the floor. :twisted:
Back the car up onto ramps :wink:
2020 - Tesla Model 3 Performance
2020 - XC60 T5
1999 S70 T5 - Bilstein touring shocks/struts, B&G S2 springs, OBX full exhaust, other misc. stuff
ThommyKent
You're still on the floor with ramps :roll:
