I followed your detailed replacement plan for the vacuum pump. As far as I can tell everything went as expected except that the pump still comes on a lot. Every time I step on the brake pedal it comes on and when I turn off the engine as well. The wife thinks that it used to never make the pumping/whining noise but it would have to come on to assist the braking when needed. Would it run too much if there were a vacuum leak? It is a 2002 S 80 T-6 but I don't drive the car very often so just not sure about the cycling of the pump and its frequency/need of operation. What are you thoughts.
Perry V.
2006 V70 brake Vacuum pump/switch 31317445 31265825 Topic is solved
No Brakes When Cold, Volvo V70 Vacuum Pump
- Been thanked: 4071 times
Definitely a vacuum leak. Primary suspect the sensor valve in front of the air cleaner box, known to fail.
TonyC52
- Year and Model: 2005 S60 2.0T SE
Hi, this is a great article but I have a problem at Step 2. I have checked the voltage and it returns zero. I went to fuse 33 and it seemed fine. Took to my local Volvo dealer and they confirmed fuse is fine. Just in case I changed fuse but still get no voltage. User manual confirms fuse 33 is for Vacumn pump only. Does this mean there is a fault in the wiring assembly or the switch connector?
UK 2005 S60 2.0T SE
Many thanks.
UK 2005 S60 2.0T SE
Many thanks.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
This pumps goes bad when there is a vacuum leak at the brake booster. As the booster vacuum drops below a certain level, the pump kicks in to bring the vacuum back to the level. However, because of the leak, the pump runs way too much and wears out (the brushed wear). Usually, the pump will run after shutting the engine off (will run intermittently for 5-10 times), or when the car is started in the morning, or when the car has just been parked and the brake pedal is depressed. Sometimes the pump can be heard running even while driving the car.
Check first the pump switch, the top plastic can break loose. Make sure the connector is fully engaged as well.
Before suspecting the diaphragm inside the booster, there are two or three places where the leak this happens: under the grey bellow inside the car, at the vacuum hose from the pump where it gets into the booster (a rubber seal), or at the diaphragm position switch seal (the sensor right near the master cylinder).
But the most common is the seal under the grey below, it gets dry then gets torn. It better to lubricate this seal before this happens with the Volvo grease #1161688 only.
The seal https://www.ebay.ie/itm/BRAKE-BOOSTER-S ... Sw14xWIM9o
Here's how to lubricate it (apply the grease on the white cylinder near the seal)
TonyC52
Any ideas anyone?TonyC52 wrote: 24 May 2018, 08:41 Hi, this is a great article but I have a problem at Step 2. I have checked the voltage and it returns zero. I went to fuse 33 and it seemed fine. Took to my local Volvo dealer and they confirmed fuse is fine. Just in case I changed fuse but still get no voltage. User manual confirms fuse 33 is for Vacumn pump only. Does this mean there is a fault in the wiring assembly or the switch connector?
UK 2005 S60 2.0T SE
Many thanks.
- June
- Has thanked: 523 times
- Been thanked: 261 times
My 04 S80 T6 has the same switch as in the OP. What is it there for in the S80? Just curious, my car had the switch go bad a few years back. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Correct me if wrong but I've read that only Turbo engines have the brake vacuum pump?
This thread helped me last May. Before purchasing I could see both rear calipers were seized. Had the dealer drop the price down $500. First thing I did when I got her home was install 4 new ATE calipers, 4 new brake hoses, 8 new ceramic pads, 4 new brembo rotors, new rear parking brake shoes, and flushed out old blue brake fluid with SL6. After this the brakes were still soft during startup?
After reading this thread I checked the vacuum pump and it wouldn't turn on. Fuse was fine. Tested the check valve switch and found it was always open. I tackled this within 1 week so I had the used dealer pay for a new pump and switch which I installed within an hour.
- oragex
Not about being turbo or not, more about the year the car was made.
- 11 Replies
- 6964 Views
Last post by Memark
- 2624 Views
Last post by DraftyBread
- 951 Views
Last post by volvo2006taj
- 933 Views
Last post by EstVolvo
- 2881 Views
