Removing lock from child seat bottom
aharres
- Year and Model: 1999 V70 T5
Does anyone know how to remove the lock from the child seat bottom? There seems to be 4 torx bolts holding the mechanism onto the back, but two of the bolts are underneath the seat cushion. Does anyone know how to remove the cushion?
aharres
Got it! If you look on the other side of the lock, you can see there is a little brass retainer keeping the lock in place. Pry the front edge of the brass retainer up over the lip in the wood and slide the retainer back (It takes some force) and the lock will simply slide out with a bit of wiggling.
- 7417 Views
Last post by precopster
- 48 Replies
- 97540 Views
- 772 Views
Last post by kiribati
- 1320 Views
Last post by Seaway
- 14 Replies
- 2691 Views
