I cannot figure out where it is coming from. Cleaned, then driven and everything is covered.
What is the typical oil leak(s) from there?
I want to fix this while it is up in the air (changing the radiator currently).
TIA!!!
Oil leak from back of block (firewall side).
- Dan McBoost
- Year and Model: 1999 V70R
Dan McBoost ● FB: Dan McBoost ● MA70.COM ●
- Has thanked: 2200 times
Can you add pictures please Dan?
Thanks,
Thanks,
- Dan McBoost
Neil, I will once I get back under there, but as said, it is covered and immobile (rad is out).scot850 wrote:Can you add pictures please Dan?
Thanks. I will take a look there and see how it looks.tryingbe wrote:Oil return rubber seal at the oil pan is most likely broken.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
#1 Turbo return to the oil pan.
#2 The pads that are bolted to the back of the block.
Dan...you have a biscuit oil cooler on the back of your 1999 too, first year for that
- Dan McBoost
Just posting for any future searching.
Using an inspection camera (for those with AWD) is very, very helpful...
It was the oil return. Some PO's mess:
After I installed the new seal (yellow):
