Oil leak from back of block (firewall side).
Dan McBoost
Year and Model: 1999 V70R
Post by Dan McBoost »
I cannot figure out where it is coming from. Cleaned, then driven and everything is covered.
What is the typical oil leak(s) from there?
I want to fix this while it is up in the air (changing the radiator currently).
TIA!!!
Dan McBoost ● FB: Dan McBoost ● MA70.COM ●
Has thanked: 2212 times
Been thanked: 1853 times
Can you add pictures please Dan?
Thanks,
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Oil return rubber seal at the oil pan is most likely broken.
85 GLH, 367 whp
00 Insight, 72 mpg
Dan McBoost
scot850 wrote:Can you add pictures please Dan?
Neil, I will once I get back under there, but as said, it is covered and immobile (rad is out).
tryingbe wrote:Oil return rubber seal at the oil pan is most likely broken.
Thanks. I will take a look there and see how it looks.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
#1 Turbo return to the oil pan.
#2 The pads that are bolted to the back of the block.
Has thanked: 1613 times
Been thanked: 4075 times
Dan...you have a biscuit oil cooler on the back of your 1999 too, first year for that
Dan McBoost
Just posting for any future searching.
Using an inspection camera (for those with AWD) is very, very helpful...
It was the oil return. Some PO's mess:
After I installed the new seal (yellow):
