This seems to be somewhat common, yet I haven't seen a solution.
AC works fine until outside temp approaches 90
'99 V70 AC Problem
- Year and Model: Many Volvos
- Been thanked: 76 times
The compressor has a thermal sensor that will turn it of if it decides the compressor is overheating. My understanding is that the condition is exacerbated by an improperly shimmed A/C clutch.
There was a good thread on the subject over on VS that includes a good writeup on re-shimming the compressor.
http://volvospeed.com/vs_forum/Ac-Therm ... 76833.html
Thank you! That was excellent.
Does anyone know what temp the switch is supposed to open at?
My thought is to replace the "bad" one with a good one (of a completely different type) and mount it on the Compressor, somehow.
- Has thanked: 2858 times
- Been thanked: 1332 times
Thanks for the info.
I hope to get a look at this in a couple of weeks. I'll remember to look for this, as well as the Compressor Clutch Gap and the Thermal Cutout Switch.
Thanks again for everything, including the reply.
Rob3
Rob3
TheDrivenMan
- Year and Model:
I'm having the same issues with my '95 850
Ice cold a/c for a while, then nothing; turn off the a/c and wait a few minutes and it is cold again.
The cooler it is outside, the longer the a/c will function normally. If I'm in slow traffic on a very hot day, the a/c fails too cool at all.
Plenty of line pressure
R
R
Just FYI:
I removed the Relay that Operates the Compressor. I disassembled it and looked at it. The Relay showed signs of heat, but it showed a Reliable Connection with my Meter. I operated the Relay several times and each time the Connection was reliable.
I placed a 12 Volt Lamp across the Relay Coil and inserted the Relay back into the car. I routed the wires from the Lamp so that I could position the Lamp near my Wipers. In this way, I can see if the Compressor is being told to turn On while I'm driving down the road.
Since then, the AC System has not failed. It has been a couple of weeks, so far. I don't know if it has to do with the Relay, or if it is just coincidence.
If things change, I'll let you know.
BTW, the Relay is in the Triangular Box nearest the Battery, with the Large Fuses. It is the narrow Relay which is closest to the Engine.
Rob3
Rob3
- 9 Replies
- 2521 Views
- 1585 Views
- 12 Replies
- 3405 Views
Last post by Jaguar xjs
- 19 Replies
- 7462 Views
- 15 Replies
- 7798 Views
Last post by tango_1000
