Dash Cam thought? Hardwiring into power.
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
I bought a real cool dash cam, and figured with the way people drive in Austin I could use it. Thinking about just sending it back for this reason… can't figure out how to hardwire it into the car. I would run the wire to the passenger side of the car. Took out the glove box and looked for a familiar wire to tap into for power. Couldn't find one. Could I tap into the footwell lights that come on when you open the door? But then the dash cam would do that as well and I don't think thats good for the battery. I was thinking of tapping into the battery wire on the stereo however I then thought about it and figured that the dash cam tapped into that could cause interference in the radio. I'm 50/50 on this whole dash cam thing. Anyone have one? I already have a radar detector plugged into the cig lighter and I don't want to get one of those dual plug cig lighters that look so dumb, I either the dash cam or radar detector hardwired. Any ideas? Thanks!!
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Hardware it to the cig lighter wiring. I've wired in some extra footwell lighting there, and it works fine. You'll have power from position I, so you don't need engine running for there to be some juice, but it won't trickle out when you're not around. Easy access, and easy routing.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
speedyt5
Ahh, cig lighter. Good idea, but I'm guessing the best way to get to that is to take the center console out which means there may be a chance of my perfect wood grain cracking. Also here is a pic of the hardwire kit, I'm assuming the wire with the the metal on it is a ground, anywhere around there to ground it to?Sommerfeldt wrote:Hardware it to the cig lighter wiring. I've wired in some extra footwell lighting there, and it works fine. You'll have power from position I, so you don't need engine running for there to be some juice, but it won't trickle out when you're not around. Easy access, and easy routing.
- S
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
There's a yellow connector on the drivers side that's intended
specifically for electrical accessories. You'll find it secured to the
steering column support.
Constant, switched, ground, dash lights, high beam trigger, etc.
There are all kinds of power sources available there.
Sommerfeldt
BEJinFbk's idea is even better - I don't have that connector anymore, since a PO did some weird stuff with some phone accessories
, but if you have it, use it.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
speedyt5
Hmmm. Are you talking about those ones with the purple release handles that plug into the yellow ones?. There are like four of them across the dash I think (when i replaced dash mounts I saw these). Anyone happen to have a pic? I just didn't want to take of the knee bolster again on the drivers side just to look as the tabs are broken and its currently being held in place with phillips screws, but I may take a stab at it later.BEJinFbk wrote:There's a yellow connector on the drivers side that's intended
speedyt5
If I did use the cig lighter where would I put that ground? Just around any metal bolt?Sommerfeldt wrote:BEJinFbk's idea is even better - I don't have that connector anymore, since a PO did some weird stuff with some phone accessories, but if you have it, use it.
- S
Sommerfeldt
Red to red, black to black.speedyt5 wrote:If I did use the cig lighter where would I put that ground? Just around any metal bolt?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 795 Views
Last post by chris S60LaRosa
- 1339 Views
Last post by mrbrian200
- 2710 Views
Last post by erikv11
- 26 Replies
- 5052 Views
- 764 Views
Last post by SVO LOU
