c70 2004 trans flush
So I did my trans flush today. I purchased the flush kit, and had it all hooked up. Started the car, And the fluid came out of the hose not the radiator. I ended up doing the 2+ gal flush from the hose. This hose was the one on the top driver side.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
I was told NOT to flush mine. Not sure why yet. Your trans still works ok?
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
C70 trans is the AW 55-50 model which volvo claims is a closed system. Same exact model trans is also used in other Import cars like toyota and also some domestics all say the fluid should be changed at a specified interval. I have 2 - 04 c70 that both had trans problems because prior owner did not service the trans. Also know others that had trans problem÷.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
1 of mine went bad at 96,000 the other at 120,000 so you never know. I will be changing my fluid very periodically and put an inline filter because the repairs which I did were not easy. Never want to have to do them again!
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
That car, that's the flow I assume. I believe I had the same result the one time I did the hose method from IPD. Now I prefer the.Robert DIY three 'drain and fills'
driving in between, and not the hose method. It introduces the new fluid slower and at intervals so it is less shock to the system IMHO.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
