upgrade spark plug wires?
- kippster41493
- Year and Model: 1994 850
I'm getting a pretty decent misfire with replaced when bought the car cap and rotor, recently done spark plugs, and old wires (not sure of brand.) I see a lot of people recommend the Bougicord brand, if for kicks and giggles I upgraded the ignition coil to the MSD would these wires stand up fine to that or should I go with a set of "performance" plug wires? just out of curiosity for now
1994 850 2.3 Turbo
1998 V70 GLT 2.5 Turbo
- project now
1995 BMW 530i
1998 Eclipse GSR - 3.5" off the ground and headers
1995 BMW 530i
Ben850
- Been thanked: 7 times
The only wires you want are original Bougicord.
They seem to be the only ones that do not cause issues.
Original Bosch cap and rotor.
MSD is ok, but unless you are at 300hp or above, the original Bosch is fine.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- kippster41493
Ok, was just a hypothetical that popped in my head from reading other threads and was curious. Thanks for the info!
1994 850 2.3 Turbo
- project now
1995 BMW 530i
1995 BMW 530i
- Been thanked: 504 times
The factory setup for 1993-1998 single ignition coil is very good:
- Spark Plug
- Bosch Cap/Rotor
- Bougicord
- Bosch Ignition Coil
I don't understand all these "upgrade" to better ignition cord, ignition coil.
These "upgrade" will not make the car run any faster or more powerful.
- Spark Plug
- Bosch Cap/Rotor
- Bougicord
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
That's not strictly true... better spark can make a real difference, especially (like Ben850 also remarked) when the goal is 300 hp and up. While the Bougicords will easily handle it, an upgraded coil can deliver a better stability under those kinds of demands. But, again, +1 to Ben850's statement - there's no need for it unless the goal is high HPs.cn90 wrote:I don't understand all these "upgrade" to better ignition cord, ignition coil.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- kippster41493
Which is understandable, it won't add a ton of power, but it will definitely be able to handle the 300+ HP Which I don't have now, will be in the future once the underbody parts/ chassis parts stop breaking
Again this post was to pick peoples brains not start a war over stock/ aftermarket because everyone's preference is different on what they do to their cars
1994 850 2.3 Turbo
- project now
1995 BMW 530i
1995 BMW 530i
- Has thanked: 1611 times
- Been thanked: 4072 times
The war will end quickly when performance/300 HP stuff moves to the Performance Forum.kippster41493 wrote:Which is understandable, it won't add a ton of power, but it will definitely be able to handle the 300+ HP Which I don't have now, will be in the future once the underbody parts/ chassis parts stop breakingAgain this post was to pick peoples brains not start a war over stock/ aftermarket because everyone's preference is different on what they do to their cars
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I was having misfire issues with my 98 S70 T5 when under heavy load and it turns out I had a bad boot on one of my cables. I went with the 8mm IPD cables, installed Volvo spark plugs and replaced the cap and rotor with Bosch parts and haven't had a problem since. These cars are very picky when it comes to plugs and wires.
- Has thanked: 312 times
- Been thanked: 818 times
True, true, true.shaker_chi wrote: ... These cars are very picky when it comes to plugs and wires.
- 3107 Views
Last post by Roger_850T
- 3915 Views
- 1958 Views
- 927 Views
Last post by bmdubya1198
- 725 Views
Last post by rspi
