While driving my 1996 855T M56 today, it lost all power output from the transmission. It happened between 1st and 2nd upshift with no noticeable sounds or crunches. The car now acts like its stuck in neutral permanently and the gear selector doesn't seem to do anything. I can see the linkage is moving at the transmission However. So did this thing grenade internally? Anything I can look at first before removing the gearbox and throwing it down a ravine? The clutch, PP & bearing all have less than 500 miles on them.
Thanks for any advice!
1996 855T M56 problem? (Inner axle shaft failure) Topic is solved
the65dartguy1
- Year and Model: 2001 S60 2.4T
- Year and Model: Many Volvos
- Been thanked: 76 times
Make sure that the axle didn't pop out, particularly the left hand side.
the65dartguy1
It appears to be in there OK. I can't accurately measure but it looks like an 1/8th" clearance between the fat part of the inner axle and the trans..
- Been thanked: 4064 times
Jack up the front two wheels and see whats spinning.
A new clutch job? Could be something has grenaded there - more likely than the trans, I think.
the65dartguy1
So it was a sheared axle inside the trans. Snapped off right at the spot for the retaining ring!
Anybody have a preferred axle supplier/brand?
And thanks for all of your help!
- Has thanked: 2854 times
- Been thanked: 1332 times
This https://www.matthewsvolvosite.com/forums ... 27#p410227 seems to be the best of what is a group of poor choices. I haven't tried NAPA myself, but I've tried one of the bad choices.the65dartguy1 wrote:Anybody have a preferred axle supplier/brand?
- kippster41493
- Year and Model: 1994 850
Carquest isn't bad, I've used them before in my V70 and never had issues with them.
1994 850 2.3 Turbo
1998 V70 GLT 2.5 Turbo
- project now
1995 BMW 530i
1998 Eclipse GSR - 3.5" off the ground and headers
1995 BMW 530i
Ive got a left hand side one in my stores from when I ruined my original doing the FWB.
Do you need the car back on the road stat?
Ill donate it for karmic points if you are tight on budget, or sell cheap if you arent.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Is Raxles no longer recommended?
Raxles no longer rebuilds Volvo axles. He couldn't get good cores which is a shame, they were the absolute best.
- 5182 Views
Last post by SuperHerman
- 3218 Views
Last post by 850 LPT
- 4661 Views
- 681 Views
Last post by smacknab
- 1142 Views
Last post by Sezon1987
