97 850 NA injector seal question
Has thanked: 2199 times
Been thanked: 1852 times
Thanks, but like I said, there are none to lose! I have pulled the intake anyway to look at the PCV system due to oil leaks, that is when I found these were either missing or never fitted. Based on what I have found in the PCV system, chances are the former!!
I have ordered new ones from FCP.
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
It does seem pretty precautionary, but the way I think is if they designed it like that there is most likely some good reason. I just like having everything that would have came stock on it. Plus they are cheap and in my case I took the injectors out to have them cleaned anyway so I figured why not? Added bonus for the "look" now because they are blue instead of the original black :)
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
The foreman said he thought they were to try to align the injectors straight. I think it is likely to ensure a tight fit of the injectors between the rail and the intake manifold and also ensure the injectors sit at a consistent height in the air-flow in the intake.
Either way they are going back on!
Thanks for the input
