How to replace ignition switch?
blue_v70
Year and Model:
Post by blue_v70 »
I have ignition switch problem (gotta wiggle the key to get the warning light off) on my 95 850, and I put a thread here a while ago, someone said that I should replace the ignition switch.i just received ignition switch from FTP groton. How do I replace it? What tools do I need?
I had a look on the steering housing, I am confused how do I open the housing??
If anyone can tell me step by step, it would be very much appreciated
Thanks
CarVolvo
Year and Model:
Post by CarVolvo »
the housing (aka clamshell) has 3 torx screws holding it. If you look under the housing you will see them. I think its a T25 and it is in there about 1" deep.. so make sure you get the longer bits or screwdriver.
Once you have that off you will see the ignition switch on the left side of it (opposite to where you put the keys in) Once this cover is off it will be much easier to see how to install it.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
blue_v70
Year and Model:
Post by blue_v70 »
Woohoo I got it replaced, a bit running around to get the torx key tho but it starts like magic, no wiggle wiggle!!
thanks guys.
