Some people have been able to catch the release with a straightened out coat hanger coming up from the bottom. Fortunately I've never had to try it.
98 S70 Stuck hood, broken hood "thing"
- Year and Model: Many Volvos
- Been thanked: 76 times
- Has thanked: 1611 times
- Been thanked: 4072 times
If the cable works smoothly and the latches are oiled don't sweat the backup, just enjoy it. It's a solid system if maintained.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Sorry, I didn't check back here last night or follow up on my first suggestion because it seemed like your cable was in tact. It's stormy here today. Tomorrow I'll take a couple of pictures and write something up. I made a little bracket for one side to connect to the trip arm.
Two nightmare scenarios that don't involve the drive train that come to my mind, especially on a road trip, are sunroof stuck open with stormy weather coming in and the stuck hood. I have 3 850's and have had to change a couple of hood latches because they were beyond getting to work freely. I was preparing to go on a road trip when I created the backup method I mentioned. Fortunately, I haven't had to use the backup cable but it's there if I need it.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
Thanks very much, i look forward to seeing them.
I'm a heavy sunroof user and also worry about being stuck open in bad weather.
Heavy piece of plastic and packing tape are in my cars, and the guides get a shot of silicon spray once a month to keep the load on the motor down. Three sunroofs in the fleet, no problems yet, even on the "troublesome" BMW
- MrAl
Hi,
Nice idea. I was lucky mine did not have a sunroof. I hate the sun
JimBee
To Mr. Al,
Here's a description of my broken hood cable nightmare prevention (I'll post it as a new thread).
There are lots of reasons to keep an 850 in service, especially when its miles aren't too outrageously high. But the reality is these cars are 20 or more years old and as we all know parts wear out.
Two parts that are not in the drive train that I worry about are the sun roof (if it gets stuck open) and the hood release cables—either the main cable from the cabin or the cross cable that links the driver's side to the passenger's side latch can fail.
There have been some instances posted on this site. In the junk yard, the way they get those hoods open is with a sawzall. I've seen a few of those and wondered if that's what brought the end of the road for those cars.
A snapped cable is most likely if the latches have been allowed to get rusty, which all have been to some degree on my 850's when I bought them. I've had to change out a couple of latches because I couldn't get them to work freely, even with plenty of PB Blaster.
The worst scenario is if this happens on a road trip, but it's bad enough even close to home because there is no easy way to get in there to trip those latches when either cable is broken. Not that you couldn't get to the latch, but you can't see it from any point underneath or even with the marker light out. Volvo probably has a tool to reach up from below, but I'm not aware of it.
So for peace of mind, installing a backup safety cable is a few hours well spent especially if you're planning a trip.
What to use:
The OEM is a solid wire cable, so I've harvested a couple of latch-to-latch cross cables from junk yard 850's. They already have a stop-ball on each end. I cut them about 60-40, so not quite in half. Then pull the wire out a couple of inches from the sheath and snip the sheath off to expose the wire when its pushed back in. After you feed the wire thorough the trip arm on the latch, the exposed end can be bent around in a circle to make grabbing it with a vice grip a little easier if you need to use it.
You could probably use a bike cable, as well, though they're usually stranded and might be harder to work with.
Procedure.
I took a few pictures but they're really not very helpful.
Remove the splash guard under the radiator.
BEFORE you cut your cable, find the path you want it to follow down by the radiator where you can access it in an emergency by removing only the splash guard. Actually bring the cable up through that path to the latch. The 850 latch-to-latch cross cables are long enough for two back up cables, but sizing one side, then the other before cutting will be helpful. Mark the sheath for cutting with a Sharpie.
If you look closely, you'll see that the trip arm on the lower part of the latch has a hole or slot that can accept and hold the stop-end of your back up cable.
Important: make sure the angle of your installed back up cable enables you to pull the trip arm so it will release. This is easier to arrange on the passenger's side because the trip arm pulls toward the radiator.
On the driver's side, the trip arm is similarly located on the latch so it pulls toward the left fender wall. For that one, I fed the cable down behind the d.s. corner marker light (under that spring) and through a hole down to below (I think there's an opening in front of the battery tray). You can see that path with a flashlight. I believe that was the shorter of the two cables.
Cut your cables to length. One end of each of the two lengths will have the stop ball at the end.
Take the cables out of their sheaths and cut an inch or so off the sheath so the wire will protrude when it's put back in the sheath. Feed the wire through the hole in the lower trip arm or slip the wire with the end-stop into the slot in the latch's lower trip arm.
Feed the wire down the path where it will stay and slip the sheath back on (which you probably don't need to do, but the wire is iron and will rust if left exposed).
I mentioned in another post that I made a small bracket from two metal duct hangers doubled together for strength that I bolted onto the trip arm on the other car using a tiny bolt from Ace Hardware (3/32" ? with a nylon lock nut). That provides a better angle to pull from down below, but I didn't use it on the later one described above.
Properly adjusted latches hold the hood down tightly, which binds the hood catch in the latch. So to operate your back up cables, I found you'll need a helper to push down on the hood over the latch to release the upward tension on the latches so the cables are easier to pull, using a vice grip. But they do work.
ps: you might be able to just use a length of galvanized wire for a quick hookup. Just twist it around the latch and thread it down below. I haven't tried that. You need to be able to pull some force on it, though, to trip the latches so you'd want it to be good and secure at the latch and heavy enough gauge.
Bonus: latch maintenance.
You can operate the latches without closing and opening the hood using the release lever under the dash.
With the hood open, douse the latches with PB Blaster. Using a screw driver with a 1/4" or slightly larger shank, lay the shank horizontally in the latch, grab the handle and end of the screw driver and press down. That should clamp the latch closed. Then use the latch's trip arm to open it again. If it's sticky, add more PB Blaster and work it like that a few times. If you can't get it to work fairly smoothly maybe add another latch to your list for the next junk yard visit.
Doing that simple maintenance once a year should reduce the likelihood of a stuck latch or broken cable.
What to use:
Procedure.
- MrAl
Hi again,
Thanks for the detailed explanation.
I included my close up pictures of the drivers side latch, two from the back of the latch and one from the side.
Looking at the picture with the blue arrow, i guess that is the lever right?
Looking at the side view pic, that same metal piece has a hole in it near the bottom, not a slotted hole. But if i tied something to that hole i guess pulling it to the left (looking at the back picture again) would open the latch?
- HoodLatchDriversSide-3.jpg (95.48 KiB) Viewed 1251 times
- HoodLatchDriversSide-2.jpg (122.91 KiB) Viewed 1251 times
- HoodLatchDriversSide-1.jpg (106.76 KiB) Viewed 1251 times
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
I lubed my latches with white lithium grease. They're working fine. But my hood is still getting stuck.I haven't tried any felt pads (I couldn't find them.) But I did notice two things:
1. The driver's side catch is "lower" than the passenger side. By a few mm.
2. The driver's side catch is angled (probably due to the less than stellar welding I had done to it), so I moved it over a little by loosening and repositioning the 10mm bolts.
And... The hood is still stuck. I was looking to see if there is any way to "lower" a latch. And there doesn't seem to be a way. You can move them side-to-side however.
Attaching pictures below of my horrible hood!
Retired:
2015 Volvo S60, T5, 85K
- MrAl
Hello there,
The only thing i can think of offhand is maybe bending the catch a little, if it only has to move over a little, but you should ask someone else here if that is reasonable as i dont know what it takes to break one of those off. If it broke it would have to be welded.
Another more drastic idea i had was to cut off the catch completely, drill two holes in the hood in the right place, and install a "U" bolt to act as the catch. Sure, that would expose two bolt ends on the top of the hood but they could be cut to length just above the hood and use chrome plated cap nuts to tidy up. There would be two cap nuts showing on both sides of the hood. This would be extremely functional because if the hood doesnt lift you can just undo the two nuts on both sides.
Downsides are it would not conform to the original Volvo "look" if you are worried about that, and also the security of the engine compartment would be somewhat compromised because anyone can come along with a wrench and undo the four nuts and gain access to the engine compartment. How much that matters i dont know because if they want it that bad they can get into it some way anyway, although they may trigger the alarm if you use one. I would bet there is some way to use another sensor though to make up for the possible alarm disfunction however.
- 10 Replies
- 2704 Views
Last post by bmdubya1198
- 1768 Views
- 60 Replies
- 8153 Views
Last post by ericmci
- 16307 Views
Last post by Medusalith
- 569 Views
Last post by JimBee
