850/P80 top torque mount fitting - Fact or Myth?
Has thanked: 2200 times
Been thanked: 1852 times
I seem to recall (maybe incorrectly) reading that if you rotate the top torque bushing 10 degrees forward they last longer. Can anyone confirm this or am I in the WD40 mist dream state?!
Bump?
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
The OEM bushing is directional - it's got an arrow on it that shows correct installation. It has weaker and stronger parts, in an effort to further lessen vibrations that are transmitted through to the driver. That's also one of the reasons most people feel more vibrations when changing over to aftermarket or upgrades. So I'd think that rotating the OEM bushing might transfer stress from the "weaker" or softer parts of it, over to the more solid parts, which might increase longevity if you get it just right, but might also increase the transmitted vibration.
- S
[Sold] '97 S70 T5
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I don't know yet if it worked to increase lifetime, but I installed my torque bushing about 4-5 years ago with a forwards rotation of about 10-15 degrees. So far it has not broken. I didn't notice an increase in vibrations.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
One tip I used, before torquing the bolt, put the car in drive against blocks and have someone in the car holding the brakes SAFETY FIRST!
Then torque the bolt. This way it is set in the position it is normally in, D, at idle.
It also helped reduce a bit of vibration with my poly mount
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Thanks for the in-site guys. I am using a lemforder top bush. I has 2 'arrows' on it on opposite sides pointing in opposite directions. What it didn't tell you is which side to point which way. The Volvo dealer had an apprentice install the bush under supervision for me for free so hopefully they got it right! They did a real nice job and even the bracket came back nice and clean. Do no it is what it is. Interesting mecheng your thoughts of putting the cat in drive prior to torqueing the tip bolt. Need to think on that one as it is a good point!
Thanks again,
kippster41493
Year and Model: 1994 850
Post by kippster41493 »
mecheng wrote:One tip I used, before torquing the bolt, put the car in drive against blocks and have someone in the car holding the brakes SAFETY FIRST!
Out of curiosity what does this do? I've never heard of that before but seems interesting :)
1994 850 2.3 Turbo :D
1998 V70 GLT 2.5 Turbo :shock: - project now
1995 BMW 530i :)
1998 Eclipse GSR - 3.5" off the ground and headers
mecheng
Post by mecheng »
Reduces stress on the rubber, think of how you install control arms, same idea. You tighten the bolt when the car is in its loaded position.
kippster41493
Makes sense, if I can add to this when I bought the car it had the poly mount on it. If were to knock the bolt loose, did the procedure would it be any more help or is it more of one shot kind of deal? (I don't know how long that new mount has been on it.)
1995 BMW 530i :)
I considered this too, but as the car is not running for a while I decided to tighten it up in the 'at rest' position for now so I don't forget to tighten it in a week or so when I hope to get the car running (part supply will determine that!).
