Yeah, weird.. I accidentally drove my car with the dipstick not pushed all the way in, and it has more power. Well, the boost came on quicker, definitely livelier. I haven't a clue if this is normal or a symptom of a problem, but there it is.. Comments?
BTW, I drove an 800 mile Round trip with the new planar front 02 sensor, and got 25mpg on a car with about 230,000 miles.. Not bad...
raised dipstick = more power?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Did you have oil spray everywhere? More power and oil everywhere would make me think you'r PCV is so clogged that the engine has a lot of pressure its fighting.
- Has thanked: 316 times
- Been thanked: 531 times
Yeah, I think you're right.polskamafia mjl wrote:Did you have oil spray everywhere? More power and oil everywhere would make me think you'r PCV is so clogged that the engine has a lot of pressure its fighting.
Check your PCV, I bet it's clogged!
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Probably it - I had too much CC pressure and thought it was the PTC (?) valve in the intake manifold by the turbo. I cleaned it and the oil loss through the rear main seal went down. But there's not much oil spray at all.. I'll check for pressure in a couple of days...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
I figured I'd have to do it. The system was redone about 6 years ago by a shop, so I will assume the can can be cleaned out and reused. I'm also going to do the bigger hose mod, too. Thanks for the input..
On the other topic, I think upgrading to a planar O2 sensor is worth it. I posted about it a month or so ago, but the splicing kit- with the official Bosch splicing block, comes with a sensor that has plenty of cable to reach the connector, so putting new connector pins on the new cable is a better way of doing the job. But the connector block works fine - it's just fiddly to put together.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 1433 Views
Last post by s10lowrider1994
- 13 Replies
- 3461 Views
Last post by alschnertz
- 26 Replies
- 5065 Views
Last post by Petskoi
- 6768 Views
Last post by jla80
- 618 Views
Last post by Vova585
