Bulb Failure Low Beam - Both Sides
CReid
Year and Model: 2004 S80
Post by CReid »
I received the message and the passenger side bulb was out. We replaced it, and two days later I got the same message, and they are now both out. Thinking it's a little two coincidental. Obviously I am no mechanic, but am needing to resolve this quickly since I may need to drive at night out of necessity. Thanks for ANY help anyone can give me!
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 40 times
Been thanked: 28 times
Post by Cees Klumper »
The owner's manual describes how to replace the bulbs. Not uncommon for two to fail shortly after one another.
jbkeene
Year and Model: 2000, S80, NA
Post by jbkeene »
make sure you are using the correct bulbs
I always replace ALL bulbs on the circuit when 1 goes out
CReid
Post by CReid »
Thank you for the replies. Replaced bulbs in both sides and checked fuses. All were fine. Still no low beams. I hate to say it, but I think I'm going to have to take it somewhere.
THAI UNG
Year and Model: 2007 V70 2.5T
Been thanked: 4 times
Post by THAI UNG »
You go and take a look under the hood,there is a fuses box sit right behind air filter housing box,open it up and check the fuse #2 15amps which is for controling both low beams and see if it is blown out if yes then it is the problem that you don't have low beam, I used to have that fuse blown out on me a few times so I put a 20 amps and never have a problem in last 8 years.Hope this helps...
Fuses
Fuses
