Hub centric rings for jaguar rims on a '98 S70 T5
SleeStak69
Year and Model: 1998 S70 T5 5MT
Post by SleeStak69 »
I found a fantastic deal on some jag wheels but I need hub centric rings to fit them on! The jag is a center bore of 63.4mm and my Volvo has 65.1mm hub bores. The bolt pattern, size, everything else is perfect but I need those hub centric rings! Where do I find them!?! Please help!
Pewter Silver Metalic 1998 S70 T5 5 Speed 8)
SleeStak69
Just called a tire shop and he said there literally no way I could put those rims on without it being unsafe :((((((
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Yeah, cuz how i understand it the jag bore is too small. If they are?too big you can use centric rings. You'd have to find a machine shop who bores the nag rims to the Volvo center bore. Then there shouldn't be any concerns afaik.
1996 855 R,
2010 V70 D5,
SleeStak69
Do you know how much a machine shop would charge and if it would be a perfect fit? I don't want to overpay but i also want to make sure it isn't a crappy ass fit. All four rims are for $220 anyways though so that's why I want them so bad
