Squeaking noise during cold idle
m96ag
Year and Model: 2000 V70XC
Post by m96ag »
Never mind. I'm just an idiot. It bolts up from the other side on the bottom.
2000 V70XC 160,000mi.
Has thanked: 1611 times
Been thanked: 4075 times
Uh oh. Still looking for that rattle noise source?
m96ag
Post by m96ag »
abscate wrote:Uh oh. Still looking for that rattle noise source?
Yep. Back to square one. With the heat shield off I had a listen with a stethoscope and it's definitely coming from the turbo. I didn't see and excessive oil or any metal shavings in the intercooler hoses though.
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Consider checking all the bolts back there anyway, as well as exhaust fittings - sound travels strangely in the exhaust system, and the flex pipe and hangers are known failure points.
- S
[Sold] '97 S70 T5
m96ag
Post by m96ag »
Sommerfeldt wrote:Consider checking all the bolts back there anyway, as well as exhaust fittings - sound travels strangely in the exhaust system, and the flex pipe and hangers are known failure points.
- S
Will do.
m96ag
Post by m96ag »
Checked the turbo for play and there was very slight up and down play and none in and out.
Sommerfeldt
Did you yank on the flex pipe and stuff some?
- S
[Sold] '97 S70 T5
m96ag
Post by m96ag »
Sommerfeldt wrote:Did you yank on the flex pipe and stuff some?
- S
Where is the flex pipe?
Sommerfeldt
Look behind the engine, and from the outlet of the turbo, towards rear. You'll see a small section of the exhaust pipe that looks like it's made of braided steel (probably rusty red). That's the flex pipe, or flex joint. :)
- S
[Sold] '97 S70 T5
m96ag wrote:Checked the turbo for play and there was very slight up and down play and none in and out.
Probably ok. It rides on bearing film once oil pressure goes up so some play is ok. Very slight is ok.
:D
