Fuel Injector Relay
FinallyGotThatVolvo
Year and Model: 1994 850 Turbo
Post by FinallyGotThatVolvo »
Hello Everyone,
I've been having issues with starting and stalling. I believe I've isolated my issues to my fuel injector relay.
Long story short, I've replaced my fuel injector relay and noticed that one of the wires connecting to the relay was loose. The wire was loose and came out hence giving me the issue of stalling and other starting issues.
Two questions,
1. Is there a silicone or rubber type connector that fits inside the relay connector that would replace the current decaying ones. When I pulled the rest out to check the condition the connectors have disintegrated.
2. Does anyone have a wiring diagram for the fuel relay injector?
As always, any help is appreciated, thank you.
1994 Volvo 850 Turbo
It's new to me!
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
The connector is not available anywhere.
I use 4 of this *on the left* and added some wires to make my own connector.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 2202 times
Been thanked: 1852 times
Other option would be to go to a boneyard and cut out what you need and connect it in.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
You are not the first to have that problem. The connector is poorly located and highly exposed. I don't think I have ever had the relay actually go bad but the connector is one of the most problematic on the car.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 13 times
Post by sleddriver »
You may find what you're looking for here:
http://volvowiringdiagrams.com/?dir=vol ... 20Diagrams
M1 10W-30 HM
FinallyGotThatVolvo
Hey everyone,
Just wanted to say thanks for the help.
I ended up chopping out the fuel injector relay and splicing it into my car.
It now runs normally, although at first it was loud as it wanted to be, maybe due to sitting for a few weeks.
Back to driving it for a while, once again thanks for the help!
It's new to me!
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Could you post a picture of the relay location and damaged wires. I have not heard of this issue. Thanks!!
Has thanked: 311 times
Been thanked: 817 times
This one does not have damaged wires, but it gives you the location.
The gray FI relay usually lives up under the shelf above the radiator, it has been pulled out in this pic. Note the 4 loose wires leading to its connector.
kahl
Post by kahl »
Ahhh, thank you sir!!!!
Aggnizzab
Year and Model: 1995 850 turbo
Has thanked: 5 times
Post by Aggnizzab »
tryingbe wrote: 04 Aug 2016, 23:10 The connector is not available anywhere.
Just wondering could you post the way you did this? And what gauge wires did you use or did you trim the old ones and install these?
