I retrofit that pocket under the glove box in mine, have 2/3 wood grain trim pieces installed, and I'd like a wood grain shift knob. There are two at the junkyard, haven't grabbed them because one has a broken button and I can't seem to remove the other one.shiloh51933 wrote:My '98 V70xc was same exact color in and out, 3 differences. The wood grain on the 2000 is flawless, the 2000 has the wood grain on the shifter knob and on the steering wheel, there's a nice pocket area under the glove box and there's third row seating.abscate wrote:And in the superior Baltic Blue, I see...shiloh51933 wrote: I just purchased a 2000 V70XCse with 160k on odo, functional AWD and super clean in/out.
My 98 v70xc blew a HG after a bad hose leak while driving and the level sensor failure to set off dash light for low coolant.
Just got a 2000 V70XCSE
- Has thanked: 316 times
- Been thanked: 531 times
- Been thanked: 4071 times
We get the cool under glovebox tray in the 1999 model...it's where we store our 99 coolness
It was a very easy job to install it in my '98. Just had to remove that awful knee bolster and its bracket.
- Has thanked: 2205 times
bmdubya1198, if you PM me I have several wood shift knobs in good shape looking for a home.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
There you go bmdubya... wood grain status!!
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
I'll let you know if I decide to get one, Neil!
Still looking for the console piece. One car at the pull a part had a decent one, but the screw mounts were mostly broken. I don't want one that's all scratched up, peeled, or straight up doesn't match. I don't want to have to go to eBay and pay $50 for it either.
Did you check the oil in the junk yard car ? If it looks clean you can drain and use for your next oil change. Charge the junkyard back for waste disposalbmdubya1198 wrote:I'll let you know if I decide to get one, Neil!
abscate wrote:Did you check the oil in the junk yard car ? If it looks clean you can drain and use for your next oil change. Charge the junkyard back for waste disposal
I prefer to mix the oil with standing stagnant water found nearby while in the yard.
Taking note of how quick the oil and water separate and how well it segregates themselves informs me of many helpful tidbits of information.
Things like the quality of the oils condition, knowing viscosity is important!
Purity of the water, for how drinkable the water is (thirsty after a long visit to the yard)
All while giving the satisfaction to knowing I'm doing my part for the environment by applying the three "R's"... Reuse, Reduce & Recycle!
ugh smh 850 Turbo fridge
Bottle the water into old coolant reservoirs and sell it to junkyard visitors
Harvest the Zika misquotes for fish bait
- 907 Views
Last post by shiloh51933
- 9 Replies
- 871 Views
Last post by misha
- 1921 Views
Last post by aethera
- 1659 Views
Last post by NJS1982
- 1877 Views
Last post by 101
