Starting issue (Bad aftermarket MAF) new Bosch MAF worked Topic is solved
ChadLee
Year and Model: 1998 V70
Has thanked: 6 times
Post by ChadLee »
About six months ago my 98 v70 would choke and sputter like it was running bad fuel. If I kept the RPM's up it would work through the problem and be ok. If my RPM's dropped below 1200, the car would die and not restart right away without a small miracle. I am not a mechanic but thought I would try and help myself and tackle a few things. I replaced the MAF, O2 sensor, cleaned the throttle body, spark plugs, wires, thermostat, coolant temperature sensor, pcv system and fuel pump relay (tested-used). The original problem seems to have either retreated or been resolved. Now, the car stars perfect every morning, every subsequent start required keeping the ignition engaged. It seems like something misses on the first try and then it fires up. I am not pressing the gas pedal. Starter solenoid? Fuel pump? Fuel filter? Injectors? Distributor? Low tire pressure? User error? Any help would be greatly appreciated. Thank you.
1986 245 DL, 1989 244, 745 Turbo and 1981 245 DL - gone to new homes
1989 245 GL - Wife's daily driver
1989 245 DL - In the works for a daily
1998 V70 - Daily driver
2001 V70 - Next project
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Codes! Read codes! Throwing parts at these cars in the dark gets very expensive, extremely fast. Did I mention that you need to read your codes? ;)
- S
[Sold] '97 S70 T5
ChadLee
Post by ChadLee »
The only code I get is the air blower motor.
Sommerfeldt
Then it could be your henway. But start by seeing if your problem gets better or worse by disconnecting the MAF - are you sure there are no vacuum leaks?
- S
[Sold] '97 S70 T5
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
"Henway?" -- a few pounds. Rimshot. Try the veal. Don't forget to tip your waitress, I'm here through Thursday. . .
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1609 times
Been thanked: 4065 times
1 kilogram
You've been MVSuckerpunched
ChadLee
Post by ChadLee »
First start of the day.....no problem
Any start after.......problem
Get a fuel pressure gauge and watch the pressure at the rail.
Cheaper way , when you get the hard start, give it a 2 second shot of starter fluid into the manifold to see if it then fires
You are trying to isolate fuel from ignition problems on the diagnostic tree.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Did you check out your fuel filter?
Retired:
2015 Volvo S60, T5, 85K
ChadLee
Post by ChadLee »
Starter fluid downstream from the maf?
I am picking up a fuel filter and replacing it this afternoon. I tackled this job on a 89 740 and it was a pain in the neck, looks to be easier on this car.
I will report tomorrow.
