My son took apart everything 2003 s60 turbo, AWD, I can't figure out what way the gray check valves go. This was not easy replacing the pcv system, everything was clogged. It runs now after blowing off huge clouds of smoke which I'm hoping were residual. I know a diagram is under the hood but it doesn't show the arrow directions on either valve.
What is the best method to check the check valves are in correctly?
I replaced all tubing and left them accessible.
S60 check valve direction
- Been thanked: 4068 times
Can you put up a picture of your sticker and we can annotate the check valve directions.??
- 4537 Views
Last post by S7turbo
- 1015 Views
Last post by erickwan
- 956 Views
Last post by KnucklesBusted
- 2570 Views
Last post by jipsy
- 16921 Views
Last post by volvolugnut
