'98 Alternator/Power Steering pump refit -- A Cry for Help Topic is solved
I displaced installation of tensioner, ingeniously.
- Has thanked: 311 times
- Been thanked: 817 times
I just looked at my 98 NA and a 97 (they are of course the same), the lower hole is a bit behind the belt path but not behind the pulley per se.
- Has thanked: 2200 times
Hah, you beat me to it! Had to run a couple of Volvo related errands first, but I'll add a couple of other photos in case they help:
Not sure if they help with the pump and the belt tensioner. Last photo is not great, but tried to show lower bolt position in relation to the belt, but my camera is not as slim as eriks so couldn't get it to focus. Lower bolt head is just visible at bottom of photo.
Wow, when the moved that ps reservoir over to the coolant reservoir in 1999 they really cleaned up a lot of hardware!
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Everything happens for a reason. Got the tensioner back on. Had to remove the upper timing belt cover to make room to wiggle the tensioner in. I used Steve's tip of putting the bottom bolt in first, then pivoting up to position the top bolt. There are not two upper holes drilled in the bracket.
Once in place, I threaded the serpentine belt (incorrect routing as it turns out) then noticed that one edge looked a little rough. I probably could reuse the belt, but I'm not going to take the chance, so it will be off to Bridgewater Volvo tomorrow a.m. for a new belt (although I suppose I could get a Gates or Conti belt at an auto parts store tonight. . .
Thanks all for hanging in there with me.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
confused_al
- Year and Model: 1996 TLA wagon
I have an extra conti belt with a few kmiles on it (replaced for shorter belt)...you can have it if you like.E Showell wrote: so it will be off to Bridgewater Volvo tomorrow a.m. for a new belt (although I suppose I could get a Gates or Conti belt at an auto parts store tonight. . .
PS: I'm off exit 33 on I-78
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- E Showell
Al, I'm all over that. 78 is my regular commuting route. I could swing by on my commute home this p.m. If you want to send me your address by p.m. I'll probably leave the office around 5:30,.which (depending on traffic).could put my near you around 6 or 6:15. If convenient that is.
'95 855 auto (sold)
'95 855 auto (sold)
confused_al
PM sent!
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
MVS for the win!!!
- E Showell
Met Al and and got his used belt on the way home from work tonight and will install it first thing tomorrow morning. It's stuff like this that makes MVS a website second to none. Matt, you've built a nice community here. Al, it was very nice to meet you and thanks again for the belt.
Thanks again to all of you for helping me out.
'95 855 auto (sold)
'95 855 auto (sold)
- 2878 Views
Last post by siboyslim
- 7081 Views
Last post by obayha
- 20 Replies
- 9295 Views
Last post by jsrnsis
- 1969 Views
Last post by sleddriver
- 1581 Views
Last post by Georgeandkira
