Radiator transmission line fittings
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
I am replacing my radiator on my 1999 C70. The fittings on the new radiator do not look exactly like the old ones. The new fittings appear to have a wider mouth and my concern is that it will not accommodate the quick disconnects. I have posted the pics of the new fittings as well as the old ones.
Does anyone have experience with these?
Pull off the fitting and check that the inner ID is the same on the brass fittings.
The Oring makes the seal, the plastic connect just keeps them from walking off. You could easily hose clamp, zip tie, or. Wire these in place neatly if the quick connects don't fit
- Has thanked: 311 times
- Been thanked: 817 times
You could, but I wouldn't. If the fittings don't work I would return the radiator and get one that fits. You will spend a few more bucks but you also won't need to be concerned about dumping all the transmission fluid out on the highway.
- 3031 Views
Last post by Larry_Dean
- 4413 Views
Last post by russoleum
- 714 Views
Last post by MrAl
- 276 Views
- 1010 Views
Last post by BCBeck
