I was working on my V70 replacing my PCV unit. I had the manifold setting to the side and it fell pulling some wires out of two harnesses just above the starter. I thought maybe the wires would color coordinate but as usual I was wrong. If anyone could send me a picture of the wiring harnesses or a description of where the go. Also the wires look like I should be able to strip the wire a little and press them back into place.
Thanks
1999 Volvo V70 GLT Broken Wiring Harness
- Year and Model: Many Volvos
- Been thanked: 76 times
Can you provide the wire colors on both sides of the connector including both the main color and the tracer color for the wires with a stripe? I'm trying to find the devices that the connectors go to and knowing the correct colors would be real helpful.
As far as striping the wires and shoving them back in place that won't work, or at least it won't work for very long. The connectors come with pins that crimp on then snap into the connector body. The other alternative is to snag them connectors off of a pick-n-pull car by cutting the wires back a couple of inches and then splicing the old wires on the harness to the replacement connectors. That is likely the easiest route since the crimp on pins take a special AMP connector tool to get the crimp correct.
- 14 Replies
- 4621 Views
Last post by CIK7
- 5580 Views
Last post by gnalan
- 534 Views
Last post by RickHaleParker
- 657 Views
Last post by rspi
- 12 Replies
- 2386 Views
Last post by misha
