Background: 98 v70 T5 was giving me fits with the PNP light show and 3rd gear only issue. So I rebuilt the PNP switch which fixed the safety mode and the car ran great, BUT it was throwing a CEL for a faulty PNP switch.
So this week I ordered a replacement PNP switch (non Volvo), and after installing it the light show has returned and the CEL remains.
I believe I installed it correctly as the reverse light trick works great and almost everything works as it should. So what did I miss? Or is the knockoff switch really that bad? I need to fix this because Texas won't pass state inspection with a check engine light and all the shops I've talked to won't touch it even though it's a non safety item. Any help?
PNP woes
- Z06killinsbf
- Year and Model: 1998 V70 T5
1998 V70 T5
- Has thanked: 316 times
- Been thanked: 531 times
Did you align it properly? Seems odd that it would still be throwing a CEL.
- Z06killinsbf
Code was a P0705 prior to me replacing with a new sensor. I literally just installed the new sensor and all hell broke loose.
I'm not sure I did it correctly, I followed a couple different methods and the one with checking the reverse light actuation is sort of what I stuck to. If that's wrong let me know and I'll adjust.
1998 V70 T5
I adjusted using the reserve lights and it worked for me.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Same here and used a lead pencil to mark the range on the connector itself. It was much easier than I had thought when I did this job years ago.bmdubya1198 wrote:I adjusted using the reserve lights and it worked for me.
- Z06killinsbf
So I've swapped back and forth between the factory PNP and the aftermarket PNP, absolutely no change. I believe it must be something different, but now the car is stuck in the safety mode and I'm not going to try driving it anywhere.
1998 V70 T5
- Z06killinsbf
Also, the switch can be removed/installed without Unbolting the cable and losing the adjustment
1998 V70 T5
- Z06killinsbf
So the tranny is in limp mode... I know this one all too well! Is the up arrow light working? Check any and all connectors nearby the PNP switch. I had a huge issue with that when I bought my V70... took me 4 months to figure out what was wrong (good thing it was a project at that point and didn't need to drive it). It was a large square connector between the fan and the front intake tube that had broken and didn't have a complete connection. Fixed it, up arrow light came back on, switched it out of winter mode, and no more limp mode!
- 801 Views
Last post by polskamafia mjl
- 1183 Views
Last post by anbran1
- 1005 Views
Last post by DEWFPO
- 559 Views
Last post by draser
- 1137 Views
Last post by techedbob
