2000 S70 Driver Side Front Axle Removal
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Back at Harry's today harvesting a driver side front axle from a 2000 S70. I did some extensive reading here and took my mason's chisel with me. Seven bolts and three taps later, the axle was mine. This was probably one of the easiest parts pulls I've done. I'm definitely sold on the chisel method.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
dosbricks
Been thanked: 4 times
Post by dosbricks »
Agreed. It has been the most reliable method for me also.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Mason's chisel method? How does that work?
Retired:
2015 Volvo S60, T5, 85K
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
You use the chisel as a wedge. Tap it up offset from the axle shaft from the bottom and the axle will pop right out.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I used the lug wrench that comes with the car. Inserted between the cv joint and transmission housing and pry.
Has thanked: 311 times
Been thanked: 817 times
Prying with anything can put a lot of pressure on the trans case. Usually not a problem just saying. The wedge is hands down the best way to go, tap it straight up.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Prying works, I've done it but it can take a lot of force and grief! I agree with Erik11.
Next time I will try the hammer/chisel method.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
7 Bolts? I only remove 3, am I doing something wrong?
E Showell
Post by E Showell »
I took the brake caliper off to get it out of the way (two bolts each side = 4 bolts). I'm probably doing something wrong. 2 strut bolts, bolt at the end of the axle. Steering knuckle pinch bolt and a nut on the bottom of the outer tie rod end, so if you count nuts and bolts and you opt to remove the brake caliper -- it is actually a total of 9, not 7.
'95 855 auto (sold)
