2000 S70 Driver Side Front Axle Removal
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Back at Harry's today harvesting a driver side front axle from a 2000 S70. I did some extensive reading here and took my mason's chisel with me. Seven bolts and three taps later, the axle was mine. This was probably one of the easiest parts pulls I've done. I'm definitely sold on the chisel method.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- dosbricks
- Been thanked: 4 times
Agreed. It has been the most reliable method for me also.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Mason's chisel method? How does that work?
Retired:
2015 Volvo S60, T5, 85K
- Year and Model: Many Volvos
- Been thanked: 76 times
You use the chisel as a wedge. Tap it up offset from the axle shaft from the bottom and the axle will pop right out.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I used the lug wrench that comes with the car. Inserted between the cv joint and transmission housing and pry.
- aa.jpg (30.41 KiB) Viewed 1786 times
- Has thanked: 311 times
- Been thanked: 817 times
Prying with anything can put a lot of pressure on the trans case. Usually not a problem just saying. The wedge is hands down the best way to go, tap it straight up.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Prying works, I've done it but it can take a lot of force and grief! I agree with Erik11.
Next time I will try the hammer/chisel method.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
7 Bolts? I only remove 3, am I doing something wrong?
- E Showell
I took the brake caliper off to get it out of the way (two bolts each side = 4 bolts). I'm probably doing something wrong. 2 strut bolts, bolt at the end of the axle. Steering knuckle pinch bolt and a nut on the bottom of the outer tie rod end, so if you count nuts and bolts and you opt to remove the brake caliper -- it is actually a total of 9, not 7.
'95 855 auto (sold)
'95 855 auto (sold)
- 1574 Views
Last post by Pretribrapper
- 925 Views
Last post by cn90
- 2758 Views
Last post by theWIFES_S70
- 21 Replies
- 5013 Views
Last post by jcgirton
- 1761 Views
Last post by cn90
