Hi
Thought I had found the transmission problem in tuning chips, but sadly not.
Had driven for a month without tuning chips and no transmission problem, so thought problem was solved.
Sunday and monday problem came back.
When I take speed of at red light the engine/gearbox starts to shudder and rpm drops. It lasts for 5-10 sec and stops.
It can happen one time when I am out to drive and normaly only happens once on one trip and don`t come back.
It can happen 2-3 times a week and then not for a couple of weeks.
Have changed engine speedsensor and rpm speedsensor (there are 2 sensors in gearbox.
Have cleaned gearbox with 12 liter oil.
There are no fauld codes.
Trottlehouse is cleaned.
Sparksplugs, cap/rotor, cables changed last year.
Is it the converter, hanging solenoid or something from the engine ?
Going crazy. Please help.
850 GLT 1992 aut.transmission problem still
Jantt..do I understand that the car shudders as you come up to a red light, while coasting down?
jantt
- Year and Model: C70 2000
- Been thanked: 2 times
It`s still in D when it happens and sometimes I have time to put it in N and then it stops and back to D and it starts again.
It`s not a perment problem so diffecult to find.
Thinking about checking every wire for bad connection.
jantt
As I understand then solenoid SL is controlling the lockup in the converter.
Could it be that one that is the fauld ?
Can see here that is possible to change it without dropping the frame : https://www.matthewsvolvosite.com/forums ... =1&t=65527
- 31 Replies
- 3853 Views
Last post by jantt
- 48 Replies
- 9782 Views
Last post by kevinwalter
- 776 Views
Last post by bjornas
- 11 Replies
- 2989 Views
Last post by charleskennedy23
- 1606 Views
Last post by foggydogg
