OBD plug wiring 94 850
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
misha wrote:If you read the thread more carefully from the begining,you would see that i thought he have n/a car...and UP TO '96 ,20V cars have Jetronic engine management.
If he'd pulled a Jetronic and simply dumped in a Motronic box, he'd have more serious issues than the OBDII-connector not working.
- S
[Sold] '97 S70 T5
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Basically....he couldn't even start the engine with mot 4.4 instead of jetronic since jetronic system have two ecu(s)...the other one is for ignition and both of them works like one.
But...with re-programmed ecu(like he allready mentioned) and with wiring modifications it could be possible.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
skloon wrote:Same thing with the 4.3 no communication with ecu I will unplug the obd1 tomorrow and see what happens
Not sure how you're going to "unplug" the obd1. Regardless, the obd1 will have nothing to do with your obd2 not working.
misha wrote:But...with re-programmed ecu(like he allready mentioned) and with wiring modifications it could be possible.
There is no wiring modification needed for using M4.4 ECU on M4.3 car.
85 GLH, 367 whp
00 Insight, 72 mpg
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The OBD-I box has a connector on the bottom and you can just unplug it.
tryingbe
Post by tryingbe »
Ozark Lee wrote:The OBD-I box has a connector on the bottom and you can just unplug it.
Regardless, OP is wasting his time on OBDI connector when he should be checking the wiring on the OBDII connector.
Maybe I'm blind.
85 GLH, 367 whp
00 Insight, 72 mpg
Post by Ozark Lee »
Since it didn't work with the 4.3 or the 4.4 I would tend to agree.
Sommerfeldt
misha wrote:Basically....he couldn't even start the engine with mot 4.4 instead of jetronic since jetronic system have two ecu(s)...the other one is for ignition and both of them works like one.
:roll:
- S
[Sold] '97 S70 T5
misha
Post by misha »
:arrow:
:wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Because that's what I already said. I don't think he'd be worried about the OBDII not working if he'd tried to drop an M4.4 in a Jetronic-managed car. I'm not even sure it's possible, even with, as you say, programming and wiring modification. I can't find anyone who's done it, and with differences in even K and LH, I don't think it can be done w/o swapping the whole shebang. Everything is different - even the MAF, for crying out loud.
- S
[Sold] '97 S70 T5
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
The car works and drives fine with the 4.4 but I threw a code and want to see what it is- I don't feel like tracing all the wires back to the ecu so I guess I will try and figure out the wiring diagram
