1999 V70T5M tailgate light on, tailgate trim repair 8628197 Topic is solved
Been thanked: 4068 times
Had some trouble with the lock. Latch sticking, lubed it, and got it working again.
Now the tailgate light on dash is on permanently, tailgate is firmly closed.
Loose wire?
Possible broken wire in tailgate loom?
I have the tailgate repair kit to do on this car so will document this as I troubleshoot
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Either the wiring loom behind the left tailgate hinge or the microswitch that tells the dash the door is open. (i guess it is a separate switch from the one that turns the dome light in the cargo area on and off). Could be out of adjustment. If it were an Audi inwould spray that switch with wd 40 really good. Solved some electronic hiccups here and there.
1996 855 R,
2010 V70 D5,
More info
Trunk lid light gets 12VDC from Pin A:16 on the CDM, ground wire is pin B:14 on the CDM, a BL-BN wire runs from the CDM to connector 24/13D then to connector 24/2C then to pin 9 on connector 24/3C (also connects on A-19 on the ECU) , then to pin 13on connector 24/25.
That runs to BL BN to pin 1 on the trunk lock motor component 3/78. and is grounded to pin 8, SB wire to 23/601 to pin 10 24/25, then SB to 23/417 common and finally grounded at 31/11 - location of that ground is in tailgate C pillar.
The 24/25 connector is high in the C pillar near the trouble spot of the wiring loom
Should be able to diagnose the continuity of the ground wire from the 24/25 and see if that or the switch is the problem,
Screen Shot 2016-08-29 at 10.06.35 AM.png (277.59 KiB) Viewed 2275 times
Screen Shot 2016-08-29 at 10.06.10 AM.png (278.05 KiB) Viewed 2275 times
Screen Shot 2016-08-29 at 10.05.59 AM.png (274.17 KiB) Viewed 2275 times
Clemens
Post by Clemens »
Always fascinating to see how many parts and wires are in our cars. Considering the low failure rate of these p80 cars can teach us alot about the importance of quality control and chosing the right suppliers.
1996 855 R,
2010 V70 D5,
Update - I found broken pieces in the brass part of the tailgate lock and will need a new one.
FCP has the entire thing but its 160 USD - crap on rye. Thats like 100 years of oil changes.
PnP is probably the way to go on this - pictures to come.
BTW - Im claiming one Viking horn for getting the latch trim piece off in once piece - Ill claim the other if I get it back in in the same state.
Volvo Tailgate Hatch Lock (V70) - Genuine Volvo 8628197
Has thanked: 2203 times
Been thanked: 1852 times
Ouch! Have you looked at the prices of door actuators?? Just got the tailgate trim strip from GCP in Sweden. Total delivered was $180 CDN. Got it in 10 days. Might have got it cheaper if we could wait from on-line dealer as it is on backorder of 6-8 weeks. Pre-Covid that was a $90 CDN part!
scot850 wrote: 16 Jun 2026, 08:16 Ouch! Have you looked at the prices of door actuators?? Just got the tailgate trim strip from GCP in Sweden. Total delivered was $180 CDN. Got it in 10 days. Might have got it cheaper if we could wait from on-line dealer as it is on backorder of 6-8 weeks. Pre-Covid that was a $90 CDN part!
What’s the part number on that trim strip? Asking for a friend. ….
Part # 9483520. Dealer should be able to get it but on the 6-8 week timeline for not a huge amount more than from GCP.se. Also I don't know how much you will get scammed in the US for a part shipment from out of country.
Good Luck!
Interesting
Skandix lists parts for upper and lower trim , with upper discontinued.
But…. They have a kit !
https://www.skandix.de/en/spare-parts/b ... t/1072591/
I might put an order in for these pieces. Shipping might be nasty
