What do I need to remove to clean out evap area.
- Has thanked: 2210 times
Remove the heater fan motor and using a bendy mirror on a stick will give you a good idea of what is in there. The only way to get full access would be to remove the whole dash, at which point you'd be as well fitting a new one after cleaning out the housing. There was a recent post by someone on how they cleaned the evaporator using a foaming product.
- Has thanked: 1611 times
- Been thanked: 4075 times
If you pull the fan you can get a good look at the evaporator from inside
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
After you clean the box, install a filter.
- 575 Views
Last post by Raul_duke
- 799 Views
Last post by Olegs855R
- 1435 Views
Last post by 454cid
- 365 Views
Last post by warmblood58
- 10 Replies
- 7255 Views
Last post by SuperHerman
