2002 S80 - Loss of Dashboard Functions
mudcat
Year and Model:
Post by mudcat »
I have lost all dashboard functions: fuel, tempertature, tach, speedometer are all dark. Prior to this I had a SRS error code on the screen.
I hope this doesn't have anything to to with the ECM.
Any help is appreciated.
Just sold my V70, with 144k. I knew that was a bad idea.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
Did you check the fuse? I've reseated fuses on my dad's S80 to clear up a "limp home" mode the car went into.
Also -> Amazon link
mudcat
Year and Model:
Post by mudcat »
matthew1 wrote:Did you check the fuse? I've reseated fuses on my dad's S80 to clear up a "limp home" mode the car went into.
Checked all fuses, pulled the ones associated with the dash, and ecm, and nothing. I also replaced the battery becuase when I went to check the water, it was really low. A battery test showed a real low charge and it was 5 years old.
2002_280_Owner
Year and Model:
Post by 2002_280_Owner »
I am having the same problem but my drivers side window and locks will not work either. Are you still having the problem?
2002_280_Owner
Year and Model:
we have had it to 2 different places and they said it needed to be taken to the dealer to have computer reset will no tom if this works :?:
mudcat
Year and Model:
Post by mudcat »
This has become an intermittant problem. The dashboard has not worked at all when I drove to work the past two days, however, when I go out at lunchtime and drove it, the dash functioned normally. Both days, the car has been sitting in the hot sun.
This has to be a power supply problem to the dash.
I am going to try the dealer first, but I am not real confident with these guys for a intermitant problem. I need to get a wiring diagram so I can start hunting for a loose terminal.
:evil:
2002_280_Owner
Year and Model:
well mine is at the volvo dealer i waited about a hour and a half and they were not able to find anything so they gave me a loaner and said it might take them a day or so to figure it out.
2002_280_Owner
Year and Model:
just got got the car back from dealer had to replace the driver door control module now everything is back to normal and had to reprogram the ecm
mudcat
Year and Model:
Post by mudcat »
Dealer diagnosed the problem as dim module. Dealer quoted $850 for a new part. I found a used dim from an independent volvo parts guy for $65. I will let you know if the used part works.
Thank God for the internet.
eeguy
Year and Model:
Post by eeguy »
Just like mudcat my car was sitting under the sun and very hot. I took the car to the dealer and they told me that they needed to update the ecm software due to a clitch that will cause the problem. I paid 118.00 for the software update. I think they are hoping it will fix the problem. I will update after a month.
mudcat
Did changing the dim module fixed the issue?
