Axles rebuild update.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
According to Marty @ Raxles he will rebuild non turbo axles if you provide the core. Center bearing has to be intact and usable if you are rebuilding the right side axle. He no longer does turbo axles in view of the prohibitive cost of the CVJ's. He says he has lots of NA components available and will therefore rebuild those if you supply a core. I didn't ask him anything about models there than 850. So, no more 850t rebuilds! He did say however that the NA axles are fine to use though theoretically less robust, so it looks like NA axle on 850t will be the only option through him. Otherwise, whatever else is out there.
- Year and Model: Many Volvos
- Been thanked: 76 times
Good information. Thank you.
- Been thanked: 504 times
FYI,
When I bought the car a few years ago, after checking records, the local Volvo dealer used a standard N/A axle in my 1998 GLT S70.
Zero issues using N/A axle in Turbo model.
In retrospect, Volvo should have used the same axle for all models (N/A, GLT, T5), it makes more simple for everyone.
But the Swedish engineers have a way to make things complex!
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
I bought this one last year for $56 from Advance Auto Parts locally.
https://www.amazon.com/GSP-NCV73503-Ass ... 827bddbe3a
So far so good, it comes with a lifetime warranty, kept the receipt and UPC just in case. It gets the job done.
I considered Raxles but needed a turnkey same day thing and that wasn't going to happen.
I figured worst case is the axle goes back to AAP and they refund me my money, and I got a year or two's use out of it. As far as I could tell online, you kinda roll the dice with any imported axle if it isn't OEM.
1995 850 GLT Wagon w/ 200,000 miles
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
seems the link doesn't work..wheelsup wrote:I bought this one last year for $56 from Advance Auto Parts locally.
https://www.amazon.com/GSP-NCV73503-Ass ... B001B09YSM
- Has thanked: 2864 times
- Been thanked: 1332 times
Link fixed in Wheelsup's post above ^
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
The axle size/design is based on the rated torque; thats why they are different. N/A may work fine but it will have a shorter life; especially during wheel spin then a large amount of hook up which causes lots of stress.cn90 wrote:FYI,
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
polskamafia mjl
- Has thanked: 19 times
The only way this makes sense is if they use the turbo axles on all models.cn90 wrote:In retrospect, Volvo should have used the same axle for all models (N/A, GLT, T5), it makes more simple for everyone.
Not really, the dealer installed the N/A in my S70 GLT, zero problems during the last 60K miles.
@mecheng, I understand each engine has its own torque, my point is the difference is not that much, why Volvo engineers could not develop an axle that fits all 3 engines? That makes the catalog more simple to manage. If you look at the N/A axle, the diameter is quite beefy, it can handle Turbo engine.
- Has thanked: 312 times
- Been thanked: 818 times
Good to know, but so far we have a sample size of one. There are a lot of P80 turbo cars out there. Many with larger turbos than your GLT. And yeah, those dumb engineers, why didn't they just look at it???cn90 wrote:Not really, the dealer installed the N/A in my S70 GLT, zero problems during the last 60K miles.
The turbo axles also have a different (bigger) outer CV, FWIW.
EDIT: Come to think of it, you can definitely find posts about axles snapping, even Volvo ones. Hmmm ...
- 1587 Views
- 3952 Views
Last post by thudson
- 9 Replies
- 1927 Views
Last post by precopster
- 1190 Views
Last post by rmmagow
- 1293 Views
Last post by Seaway
