OK,
Here how it goes.
Volvo V70 SE 2000 350K km on it.
1) when the car is cold, it starts no problem
2) When the car is warmed up, the car won`t start.
- All lights are on
- I can only here some kind of hissing noise.
- After a few minutes of trying, it does start.
Any clues gentlemen ???
Thanks
Francois
car starts cold but once warm dies on me
- Year and Model: Many Volvos
- Been thanked: 76 times
Is the lamda light on? Have you had the codes checked? Does the temperature gauge read normally?
It could be many things but without a scan it will be difficult to tell.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
How hot is it in Montreal this time of year?
M1 10W-30 HM
M1 10W-30 HM
- Been thanked: 504 times
Symptoms are very suggestive of bad ECT sensor.
I used to live in Montreal, same weather as Burlington VT or Albany NY etc.
- Has thanked: 311 times
- Been thanked: 817 times
Bad ECT sensor is a good idea.
You can check the ECT's resistance to find out, e.g. https://www.matthewsvolvosite.com/forums/vie ... 6&start=28
Thanks for the answer. I will check. But in fact. No codes from lambda.... Weather is not that hot. Just that when engine is warm i cant get the car to start. When i try to start the engine I get the hissing noise with sometimes engine reving up. After 10-20 times it starts. But sometimes it starts systematically. No problems...
- Has thanked: 2197 times
- Been thanked: 1851 times
Check for vacuum leaks. Car runs richer when cold, and maybe running lean when hot. Also check fuel pressure at the rail when cold and hot.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
So its cranking over but won't start?flahaye wrote:Thanks for the answer. I will check. But in fact. No codes from lambda.... Weather is not that hot. Just that when engine is warm i cant get the car to start. When i try to start the engine I get the hissing noise with sometimes engine reving up. After 10-20 times it starts. But sometimes it starts systematically. No problems...
Or does or just hiss when I try to crank it over?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Sorry guys got sidetracked by persoanl issues.
For the last post. I just hear the hissing noise. No cranking.
I got suggestion to replece the ignition switch but same issue.
Let me know if any other ideas.
It is getting annoying be ause car starts in the morning but when istop anywhere, it can take up to 5 minutes before it starts.
Always hearing that hissing noise but at one point it cranks up.
Thanks
Francois
Thanks
Francois
Check the fuel pressure. Needs to be >43 psi. Once warm I find the pump pressure drops off. Have you replaced the fuel relay?
Have the car read for failure codes. Could also be an issue with the ETM.
- 1352 Views
Last post by Nevada1906
- 4662 Views
Last post by oldvolvos
- 17 Replies
- 1918 Views
- 1166 Views
Last post by SSTurbo
- 11 Replies
- 6123 Views
Last post by rspi
