Security immobilized
Iloveandhatemyvolvo
Year and Model: 1999 V70 XC
Post by Iloveandhatemyvolvo »
I will try to keep this simple
1999 v70xc 144,000 mi. Good battery
I believe it is an immobilizer/ security issue. Car started in the morning, ran fine. Came out of the store, no go.
All lights on dash come up, fule pump pressurized, windows, lights work
Door locks do Not work.
I have had the car for roughly 6 months and have not had this issue but have read many things about it and the easy fixes, I have tried all of those.
Nearest Volvo dealer is 2.5 hrs, nearest import shop is 1 hr. I really would like to stay out of those. Any help that can be offered will me much appreciated.
I am somewhat inclined technically, know how to use a meter and such. But still am at the I need it spelled out stage.
Thank you all again,
After re-reading my post I realized that I did not say that it will not crank over.
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
I don't have any experience with the immobilizer but you may want to read through this thread while you're waiting for a better answer.
https://www.matthewsvolvosite.com/forums ... =1&t=64931
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Try starting it in neutral. The immobilizer on a '99 doesn't kill the starter, it kills the ignition about 1/2 second after the car starts. It sounds almost like a PNP switch issue which will cause the starter to not work. You can also try to quickly row the shifter back and forth from 1st to park a dozen times or so and then try again.
