smoking dip stick new pcv system
treviob
Year and Model: 1996 volvo 850 base
Post by treviob »
ok just replaced pcv system now I have smoke coming out of the dip stick like a train non stop any ideas on what the problem could be
Has thanked: 311 times
Been thanked: 817 times
First thing to check when that happens is for leaks or mis-connected hoses.
- is the intake manifold seated properly?
- are the two hoses on top of the oil trap switched, or hooked up the right way?
- are all the hoses hooked up?
Also, did you clean out (or at least check) the ports from the oil trap into the block?
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
I'd also consider a pinched hose. This sounds a lot like vacuum isn't reaching the crankcase.
5 others that came and went
