Yes they are both the same and that's a good price for the Bosch part (and the right part), fine to jump on it. 137k it isn't even half way if you want to do the maintenance.
Connector is a good point, but that can be tough to diagnose. A junkyard MAF (i.e. a known good one) helps with that.
Control Module replacement on 1997 850
- Has thanked: 312 times
- Been thanked: 818 times
I did note that you mentioned the connector. What am I looking at for that? Do you mean the little electrical plug that I unplugged from the MAF or the physical tubing itself?
If it is the little electrical plug, what should I be looking for?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
About your edit:......N O ! ! !
About connector.....it's clipped and it can't be loosened or something like that.The problem is in wires which connects to pins....before the connector itself.
The only way is to secure the wiring towards down:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2299 Views
Last post by yagger
- 2131 Views
Last post by yagger
- 10 Replies
- 2894 Views
Last post by dylan_iker
- 11 Replies
- 7388 Views
Last post by Vovoroom
- 7182 Views
Last post by br0dy519
