Haha, good joke.
All joking aside, the # of valves is in the VIN:
https://en.wikibooks.org/wiki/Vehicle_I ... /VIN_Codes
B5202S 10Valve
B5252S 10Valve
B5204S 20Valve
B5254S 20Valve
B5204T 20Valve
B5234T 20Valve
B5234T5 20Valve
Spark Plug Cover Bolt Thread Size Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
Haha, another good joke, i.e. no, not really. The number of valves is not in the VIN, it's not that simple.
The VIN can get you there, because with the VIN you can look up the engine code, and the engine code does include the number of valves.
That wiki link there also doesn't explain how the engine codes work, but it's like this: the number of valves per cylinder is in the fifth position of the engine code, so a VIN 57 car (6th and 7th characters of the VIN) decodes to engine code B5234T, which means
B = Benzene (i.e. gas, not diesel which would be D)
5 = 5 cylinders
23 = 2.3 liters
4 = 4 valves per cylinder
T = turbo
5 cylinders x 4 valves = 20 valves (but by now you just want to read the plastic cover, I know!)
For a North American P80 car, the specific links at Volvo are super convenient for decoding the VIN. For a 97 use http://new.volvocars.com/ownersdocs/199 ... n1997.html and just change the year in the URL for other years (http://new.volvocars.com/ownersdocs/199 ... n1996.html etc.)
5 = 5 cylinders
23 = 2.3 liters
T = turbo
98v70dad
- Year and Model: 98 V70
I like it until I have to take it off and put it back on. I've considered leaving it off more than once but I like it even though arguments could be made that its useless. Maybe next time I'll leave it off (but I like it).
- 1278 Views
- 3075 Views
Last post by Roger_850T
- 11 Replies
- 19504 Views
Last post by volvolugnut
- 14 Replies
- 1812 Views
Last post by EngineeringBloke
- 3902 Views
