94 850 Keep losing all electricity
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
I will periodically lose all electrical power- it seems to happen when I slow down- I have cleaned and re-tightened the battery cables- the alternator puts out power and the battery holds a charge- is there a relay that swiches all the power ?
JDS60R
Been thanked: 3 times
Post by JDS60R »
Wires from battery to main fuse box have always had a corrosion issue. Many posts here on how to replace or improve.
I am assuming you mean all electrical power not just engine shutting down.
Retired
Been thanked: 504 times
Post by cn90 »
You either have to drive faster (j/k) or search forum for B-Cable issues.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Don't forget the ground strap to the block, as well as the battery ground cable. Either of those could interfere with the alternator getting power out of the engine and into the rest of the car.
5 others that came and went
Has thanked: 311 times
Been thanked: 817 times
Next time it happens, jiggle the key ever so slightly. Or, try to replicate the problem that way. This is to test the electrical portion of the ignition switch, very common faliure.
skloon
Post by skloon »
The ignition switch is only 3 months old- the old one was sticky and I had a spare- does the 850 have the B cable issue, I thought that was only v/s70s ?
B cable issues are uncommon on the 850, you are correct. However corrosion at the main starter cable end, where the wire goes into the lug, is a common problem. That suggestion for grounds is looking good too.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Positive battery cable(b+) failures ARE common on these cars...but the part from battery to starter.The other part is going from starter to alternator and is not a problem...if erikv11 was thinking about that one.
I also had a bad one few years ago.
You maybe have a problem with both...b+ and negative cable major voltage drop.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Yeah, I have replaced the battery-to-starter cables already on three of my cars including two 850s; those are definitely an issue, especially at the battery end. Feel the cable end after using the car, is it getting hot (it shouldn't)?
Here's what I mean: the cable from the battery to the fuse box is a big problem on 98-00 cars, including at the end in the fuse box. On the other hand, the fuse box end of the cable is essentially zero problem at all on the 850s. Check the cable ends near the battery first.
Has thanked: 1609 times
Been thanked: 4064 times
It's a 22 year old car being used 3x past its typical life. Everything is suspect. It's a lot faster to diagnose by method than by symptom/lookup table approach.
Here it's battery, cables, grounds.
Do you lose all power to everything?
How old is the battery ?
