Here's the one I'm talking about.
https://www.matthewsvolvosite.com/forums ... 3&start=20
Timing Belt Job Gone Wrong... '99 S70 T5
- Has thanked: 316 times
- Been thanked: 531 times
Haha, I'll take a look.j-dawg wrote:Look for an unplugged connector near your right headlight. I had tucked one away there once and spent a few days wondering why I had no spark or fuel. Plugged it in and determined conclusively that I am an idiot.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
I was doing a t belt, tensioner, idler,water pump and resetting the cvvt's. After job was done misfire...hmmm, I reset everything 3 times. I locked came and crankshaft with locking tools but still misfire. I'm like what the fuck? She ran perfect b4 hand, I had a WP with a bad bearing so I replaced everything with factory parts. Anyway I found 3 bad coil packs.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
How does that all happen at once? Mine was an understandable screw-up. That's just a very annoying coincidence! It drives you nuts when you think you did something wrong on one job and it's a totally separate problem.
- shiloh51933
Exactly, I was swapping in new WP and I removed one of the 2 cvvt's on my wife's '04 XC70 to replace a leaky seal and I thought I reset the cvvt wrong but everything was lined up properly. The cvvt's on my wife's '04 aren't spring loaded, there neumatic so I eventually locked cams and crankshaft. I couldn't figure out why 3 of them went, battery was unconnected while working but she did have 160k.bmdubya1198 wrote:How does that all happen at once? Mine was an understandable screw-up. That's just a very annoying coincidence! It drives you nuts when you think you did something wrong on one job and it's a totally separate problem.
pvfjr
- Year and Model: 2004 XC70
- Been thanked: 3 times
I just had to replace 2 coils on my 99 S70. It was a project car than ran fine until the PO overheated it and blew the headgasket because he didn't keep his leaky radiator topped off.shiloh51933 wrote:bmdubya1198 wrote: I couldn't figure out why 3 of them went, battery was unconnected while working but she did have 160k.
I replaced one coil due to a misfire, and the car ran fine until it warmed up, then another coil went bad.
Yes, the car is running better than ever now (other than some constant clicking from the top end that I think is unrelated)! It turned out the CVVT hub had failed. We replaced it and got it running, but it was misfiring on 2 cylinders. After a bunch of testing injectors, coils, etc. I fine-tuned the adjustment on the exhaust cam sprocket to make sure everything was lined up as precisely as possible, and it was still missing. After 3 days of us two morons messing with every little thing, we ended up swapping the first and second coil wires and everything instantly smoothed out.pvfjr wrote:So did you ever get it running? What was it?bmdubya1198 wrote:Mine was an understandable screw-up.
The lesson here was to always check firing order, even if you think you know it's right. Distributor ignition systems are so much easier...
Thread closure..the colour assignments for the coil on plug wires are documented in the wiring diagrams and in this thread
...and to MIJ....page 5 - he totally nailed it.
Btw, have you made sure your ignition order is correct? I think even with ignition packs it would be possible to get a couple out of order...that may be all that's wrong.
I've already had to quote them once!
- 5286 Views
Last post by jimmy57
- 23 Replies
- 17230 Views
Last post by jonesg
- 22 Replies
- 3211 Views
Last post by precopster
- 1269 Views
- 1894 Views
Last post by obayha
