Hi All,
I have a 2001 S80 (2.4 170BHP) that has started running very rough, sounds like it is not firing on all cylinders, MIL light is on. I have had an error for a long time with the VVT Solenoid, so im ignoring that for now. It now has an error in reference to the Throttle Position sensor.
So i plugged in my Vida and got the attathced screenshot. Am I right in thinking that this is most likely going to be the ETM?
I was thinking of getting one of these to fit?
http://www.ebay.co.uk/itm/CONTACTLESS-E ... SwJQdW~4Fo
Any Thoughts?
2001 S80 2.4 Running Very Rough (ETM??)
- Been thanked: 4068 times
Looks like ETM failure, yes
Ok, is it worth seeing if I have the 2006 update and trying to run the ETM test to confirm?
Has anyone done the contactless replacement? Im presuming you need to solder something, and cut the spindle that used to extend into the old sensor?
Thanks
DJH
Thanks
DJH
harisibnmaheer
- Year and Model: 2002 S80 2.4L
Hi Djh82uk,
I have same problem...One week ago i was tried to repair the ETM with Sacer TPS.
Alhamdulillah, it's works.
You can see the tutorial and discusing about the Sacer's installment on : https://www.matthewsvolvosite.com/forums ... 4&start=10
- 14469608_345997502406876_3194711281661679299_n.jpg (54.86 KiB) Viewed 1583 times
- 14462748_345997545740205_4714635337977021549_n.jpg (102.1 KiB) Viewed 1583 times
- Year and Model: Lots
- Been thanked: 128 times
I don't think a Sacer will repair that particular ETM because there is a failure of both sensors at the same time (highly unlikely) and points to a faulty board.
You have VIDA so go to Communication-Network tab then highlight the ETM icon. It will report the 2 x software part numbers that your ETM has installed. Show me a screenshot and I'll tell you if it's updated or just do the ETM test. In the ETM sweep test the actual software numbers aren't revealed.
When replacing with a used ETM matching these 2 software part numbers will ensure the engine rums properly.
Thats a good point and makes sense, does that mean I will likely need to buy a used ETM from ebay etc and update it with the Vida?
Not sure how much hassle I want with this car (it's surplus to requirements and just want to sell it now)
Thanks
Thanks
You can't update it with unlicensed software and a license sets you back mega trouble and complication. For a one-off software match just fit the used ETM and drive it to a dealer and ask for a sw reload for the ETM. This is assuming your replacment unit's sw numbers don't match, of course.
Dealers won't be involved in most cases with fitment of used components as it opens up a can of worms when payment is due and things didn't work out.
- 967 Views
Last post by ndphotonl
- 436 Views
- 1362 Views
Last post by Gymbo
- 11 Replies
- 1774 Views
Last post by Roger_850T
- 22 Replies
- 1859 Views
